DSS axle grease?!
Can I use standard heat grease for the axles or do I have to get the grease from Honda which is for sure hella expensive? Have DSS stage 2 axles a speacial grease vs honda oem axles? Damnit I loosed a boot on my new DSS stage 2 axles and now this shity grease is every where.......
im almost positive any heavy grease will work, you can strip off old grease/grime easily with brake cleaner. I would call them up and see if they recommend any special grease for the joint, however.
