no more hyper blinker please!!!!
Old Aug 1, 2003 | 06:47 AM
rage237's Avatar
Default no more hyper blinker please!!!!
how do i make my cars blinker flash at a normal rate???
i have LED bulbs in the rear and soon to be in the front..will my hyper blinker stop once i have all LED's??
or do i need to throw some resisters inline so the little black box thinks there is regular bulbs in there and that they all work!!
i have posted this on a few other boards and got no answer at all
this fourm is alot better info wise so i hope someone hear can help
thanks
Old Aug 1, 2003 | 07:09 AM
arw321's Avatar
Default Re: no more hyper blinker please!!!! (rage237)
What is wrong with normal bulbs? The LED's are causing all your problems.
It won't stop when you have LED's in the front as well. Switching back to normal bulbs will solve your problems.
Adam
Old Aug 1, 2003 | 07:24 AM
rage237's Avatar
i have all clear tails and need the LEDs to get the color needed to keep the cops away and also to keep the clear look when there off..i think i can just use some resisters to trick the car to think the regulare bubls are in there..i was hoping someone on here has done this and would know exactly what i need to do it
Old Aug 1, 2003 | 07:35 AM
raene's Avatar
I was gonna say you need some resistors... but I'm not sure what kind of resistors you'd need
Try in the appearance/cosmetic forum, I'm sure they'd know.
Old Aug 1, 2003 | 11:34 AM
Relic1's Avatar
pick up 6 ohm 50 watt resistor for each bulb at a good electronics parts store and wire them in parallel to the bulb. Your blinker will blink slow even if the bulb is out though....
Old Aug 1, 2003 | 12:02 PM
rage237's Avatar
kewl thanks
so 6k ohm or 6 ohm?
and 50w?
any other possibilitys?
i work for a scanner repair company so i might have something
Old Aug 1, 2003 | 02:19 PM
Relic1's Avatar
Default Re: (rage237)
6ohm (not 6k) it simulates the load that the bulb would have on the blinker relay.
50 watt because 6ohms across 14volts is ~33watts of power.
Old Aug 1, 2003 | 02:25 PM
rage237's Avatar
ok
sounds good
Old Aug 2, 2003 | 12:35 PM
twuelfing's Avatar
you can buy flasher modules compatiable with the lower load of LEDs
i like the idea of lowering the power useage as a performance gain to keep the load on the alternator as low as possible so resistors are bad in my book. I know it would never be noticable, however it makes me feel like a better person. Go get the correct flasher module.
Old Aug 4, 2003 | 10:56 PM
rage237's Avatar
Default Re: (twuelfing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twuelfing &raquo;</TD></TR><TR><TD CLASS="quote">you can buy flasher modules compatiable with the lower load of LEDs
i like the idea of lowering the power useage as a performance gain to keep the load on the alternator as low as possible so resistors are bad in my book. I know it would never be noticable, however it makes me feel like a better person. Go get the correct flasher module.</TD></TR></TABLE>
where would i find one of them???
will that fix my brakelights too?
Old Aug 4, 2003 | 11:18 PM
Mr. Choi's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rage237 &raquo;</TD></TR><TR><TD CLASS="quote">i have all clear tails and need the LEDs to get the color needed to keep the cops away and also to keep the clear look when there off</TD></TR></TABLE>
why dont you jus put the oem stuff back oh, clear in the rear looks ugly imo.
Old Aug 5, 2003 | 06:29 AM
jweller's Avatar
Default Re: (Mr. Choi)
cheap *** DIY adjustable blinker relay. you'll have to play with the resistor numbers to get what you want exactly but this is the idea.
http://www.andrews.edu/~johnso....html
VTEC_Viking
Lighting
Feb 27, 2009 08:40 AM
hondamonkey
Mar 29, 2006 01:33 PM
M u n k i
Mar 29, 2006 07:19 AM
5thgenlude101
Aug 5, 2003 11:37 AM
TypeR1558
Jun 27, 2001 08:51 PM
