Launching with 7lb flywheel on slicks all motor???
Old Aug 1, 2003 | 02:21 AM
Fobtions's Avatar
Default Launching with 7lb flywheel on slicks all motor???
i recently tested my car out fo r the first time on slicks at a 1/8th track. And was wondering around what rpm to launch at.? The car is a 89 crx si with a b18c w/itr pistons, and bolt ons. The tranny setup is open diff b16 s1 tranny with CM 7lb flywheel and exedy street clutch. using 22X8X13 m&h slicks.
results from launching at 5500-6000rpm
reaction-0.619
60ft-2.0
e.t- 8.800
mph- 80.097
reaction-0.580
60ft-1.972
e.t-8.985
mph-78.273
Was just wondering if i should try a higher launch rpm to maybe improve my 60's. ?
Old Aug 1, 2003 | 02:31 AM
SlicksMH's Avatar
Default Re: Launching with 7lb flywheel on slicks all motor??? (Fobtions)
Check out the post below you changing the gears at certain RPM maybe this will help you. John@M&H
Old Aug 1, 2003 | 02:34 AM
Fobtions's Avatar
Default Re: Launching with 7lb flywheel on slicks all motor??? (SlicksMH)
that post below this is total BS. BTW
but im gonna try certain shift RPMs
cool thanks, by the way these m&h slicks are the greatest thing ever!!!!
Old Aug 1, 2003 | 02:36 AM
SlicksMH's Avatar
So what air pressure are you running @. John@M&H
Old Aug 1, 2003 | 02:38 AM
Fobtions's Avatar
i had em at 14 in the beginning, but was spinning.
so i tried 9lbs but was too little and couldnt steer.
i found 11 was perfect
but im thinking the gauge i had was inaccurate
also stopped racing that night because the tires were rubbing the suspension sometimes.
Old Aug 1, 2003 | 02:42 AM
SlicksMH's Avatar
Do you do a long burn or a short burn out.
Good Job you get that fixed right away
Old Aug 1, 2003 | 02:48 AM
Fobtions's Avatar
Just short 1st gear burnouts since the track seemed to being hooking up very well, it is brand new. i tried a couple long burnouts and hit 9.0's. Oh and is it necessary to balance the wheels?
Maybe its just me and i need more track time. thanks for the help SlicksMH
Old Aug 1, 2003 | 02:53 AM
SlicksMH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions &raquo;</TD></TR><TR><TD CLASS="quote">Just short 1st gear burnouts since the track seemed to being hooking up very well, it is brand new. i tried a couple long burnouts and hit 9.0's. Oh and is it necessary to balance the wheels?</TD></TR></TABLE>
You sound like you know what you are doing . Now yes that is a GOOOOOD thing to balance. John@M&H
Old Aug 1, 2003 | 03:08 AM
Fobtions's Avatar
yah i need to get em balanced and get some spacers. they were kind of pulling to one side at the end of the track so every time i wasnt going 100% in third gear
Old Aug 1, 2003 | 06:02 AM
ExospeedAMcrx's Avatar
im going to assume that the Street Clutch may have something to do with the 60ft.s
How does it feel like. does it feel like the clutch is slipping and not grabbing enough.
The Exedy Street Clutch is a stock clutch pretty much and isnt the best for Launching on slicks. maybe with a better Puck style Disc, your car could grab harder and pull better 60ft.s
Wil
Old Aug 1, 2003 | 03:42 PM
Fobtions's Avatar
Default Re: Launching with 7lb flywheel on slicks all motor??? (exospeedAMcrx)
yah one of the main reasons i didnt drive too aggressive was the clutch. i picked up a 6 puck ACT disc today.
Old Aug 2, 2003 | 07:52 PM
good... now you can probably run better 60fts
vtibrazil
11
Oct 20, 2009 05:19 AM
underpressure02
Jun 10, 2004 02:03 PM
yellowhonda88
Nov 24, 2003 12:55 PM
cool
Aug 18, 2002 12:06 PM
JG Luder
Jun 1, 2001 04:02 PM
