Defi A/F gauge????
Old Jul 31, 2003 | 10:53 PM
94dxt's Avatar
Default Defi A/F gauge????
Is the defi air fuel gauge as accurate as say, the greddy one?, or is more like the less advanced Autometer?
Thanks
Old Aug 1, 2003 | 03:17 AM
Dee's Avatar
Dee
Default Re: Defi A/F gauge???? (94dxt)
TECHEDGE is what you need since it is a true 5volt wideband while the Greddy ,and similar setups, are 3volt semi-widebands that are horrible for tuning part throttle.
Techedge2.0a uses a Bosch LSU O2 sensor so it's cheaper on the pocket book. I have the 1.5 DIY kit with LD01 display and it only took me about 3 hours to construct both parts.
http://www.techedge.com.au/
Old Aug 16, 2003 | 09:12 AM
Anubyss's Avatar
Default Re: Defi A/F gauge???? (Dee)
It's not the guage that is the limiting factor, it's the sensor. The stock sensor (except for certain civic vx model years) isn't accurate enough. There probably are different qualities of gauges between different brands but your oxygen sensor is what is not up to par right now.
Old Aug 16, 2003 | 10:52 PM
Dee's Avatar
Dee
Default Re: Defi A/F gauge???? (Anubyss)
Sensor and the heater circuitry. Just adding a 5volt sensor will not help if you do not upgrade the heater/signal output circuitry.
Old Apr 13, 2004 | 09:04 PM
Muckman's Avatar
Moderator in Chief
Sorry to bring this back from the dead but I have a question about the Defi A/F D-Gauge.
Would it work accurately with a 0-1v input from a wideband O2 sensor?
I called Autometer and they said theres would not work with my wideband even if it was 0-1v. They said narrow band O2 sensors are actually .5 - 1.0v, however the Defi support page shows the A/F chart starting at 0 and going to 1 volt, giving me the impression that it will work with my setup.
Opinions?
Old Apr 15, 2004 | 01:39 PM
Muckman's Avatar
Moderator in Chief
Default Re: Defi A/F gauge???? (Muckman)
Bump
Old Apr 22, 2004 | 10:35 AM
Muckman's Avatar
Moderator in Chief
Thanks!
SWAT
Engine Management and Tuning
Jan 11, 2011 03:26 PM
phearable
Jun 24, 2008 05:32 PM
NXSpoon
May 20, 2003 06:15 PM
CalvitoSol
Jul 6, 2002 06:40 PM
hardcorehonda
Jul 1, 2002 09:40 AM
