Difference between B18 and B20 cylinder head?
Old Jul 31, 2003 | 10:02 PM
KingFish's Avatar
Default Difference between B18 and B20 cylinder head?
Does anyone know if there is a difference. Iam looking into building an all-motor non vtec b20 engine. I've searched the net and did a search here for info, but could'nt find anything. So would aftermarket cams for the b18 fit in the b20 head? Is the combustion chamber the same size, valves, etc. I was just wondering because I can't find just the b20 block. I've only seen the longblock for sale. Any information would be helpful.
Old Jul 31, 2003 | 10:29 PM
ArinX's Avatar
Default Re: Difference between B18 and B20 cylinder head? (erictegra)
as far as i know the only difference is the intake manifold.
Old Jul 31, 2003 | 11:23 PM
KingFish's Avatar
Thanks, anyone else know anything?
Old Aug 1, 2003 | 07:58 AM
LSiTurbo's Avatar
yes it's all the same. That's the set up that i'm using. 12.4@108 91 CRX SI (STREET DRIVEN). allmotor nonvtec.
Old Aug 1, 2003 | 11:52 AM
KingFish's Avatar
Default Re: Difference between B18 and B20 cylinder head? (LSiTurbo)
Thanks. That's a nice time. I assume you went through the motor. New crank rods pistons. PnP head, cams, and all that good stuff? I might get oversized valves, but not sure. Did you do it, and do you think it was worth it? Again thanks.
Old Aug 1, 2003 | 12:24 PM
LSiTurbo's Avatar
The motor has not been freshend up. stock rods,stock bore, stock crank, just 12.5:1 JE slugs, a mild pnp head .5 mm over ss valves, crower springs and retainers, and crane #20 cams with itb's. it made 200whp
Old Aug 1, 2003 | 01:38 PM
KingFish's Avatar
Nice. What kind of engine management do you have. I was thinking of the hondata s200. There is a local shop that can tune it for me. You run slicks don't you?
Old Aug 1, 2003 | 01:44 PM
LSiTurbo's Avatar
I use TEC2 EMS on my car. We have pretty good luck with it. yes i use slicks on my car 22x9x13 M&H.
Old Aug 1, 2003 | 01:52 PM
KingFish's Avatar
I've seen a few dyno's of the crane cams. What does yours look like? Does your engine get alot of torque at lower rpm's. With a nice flat torque curve?
Old Aug 1, 2003 | 02:08 PM
LSiTurbo's Avatar
my torque shoots up 30whp+ from 4000-4500rpm max torque is 147 @ around 6000 rpm. The motor makes unreal power from 2500-9000rpm. its has v8 like power. i have a vtec motor in my other car and it just dont have the torque of the nonvtec. I like the Crane #20 cams better then 405a's that i also had.
Jap.Doe
Jul 13, 2012 10:29 AM
da9wonder
Oct 25, 2006 10:30 PM
justseeingifitistaken
Jul 30, 2006 07:49 PM
B20b4door
Jul 7, 2004 09:30 PM
curt801
Nov 26, 2003 06:53 AM
