how hard is obd0 to obd1
Old Jul 31, 2003 | 09:37 PM
justmotor13's Avatar
Default how hard is obd0 to obd1
whats up guys i have a 90 crx and i plan on swapping a b18c5 in it, but i need to rewire the whole car from non obd to obd1, how hard is it and what basic things do u have to change over. thanks guys.
Old Jul 31, 2003 | 09:49 PM
Agent#ONE's Avatar
Default Re: how hard is obd0 to obd1 (crx31286)
get a harness from that guy on here htat sells em, then use the distributor from the ITR motor, and get a plugg conector for the stock si harness, converting the distributor to grey plugg.
its easy, go by positions of the wiring, 4 on top, 3 or 2 on the bottom, i did the same swap, and had no problems.
Old Aug 1, 2003 | 04:28 AM
Blown90hatcH's Avatar
Default Re: how hard is obd0 to obd1 (Agent#1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Agent#1 &raquo;</TD></TR><TR><TD CLASS="quote">get a harness from that guy on here htat sells em, then use the distributor from the ITR motor, and get a plugg conector for the stock si harness, converting the distributor to grey plugg.
its easy, go by positions of the wiring, 4 on top, 3 or 2 on the bottom, i did the same swap, and had no problems.</TD></TR></TABLE>
Get an OBD0 to OBD1 conversion harness(Here is the harness you will need), run the ITR distributor and O2 sensor. Let me know if I can provide a harness or any help.
Jason
Old Aug 1, 2003 | 09:54 AM
Agent#ONE's Avatar
Default Re: how hard is obd0 to obd1 (Blown90hatcH)
yep, thats him
DaX
Oct 29, 2018 05:07 PM
CivCruise
Sep 10, 2009 07:49 AM
88ED8
13
Jan 10, 2005 04:21 PM
89 JDM CRX
Mar 21, 2004 01:49 PM
