Knock sensor code
Old Jul 31, 2003 | 08:07 PM
Fardoche's Avatar
Default Knock sensor code
I'm getting the knock sensor code on the ecu after doing Sir swap. Before installing engine, I noticed the sensor was physically broken. Could using the car without sensor cause anything bad? If I run good gas, in theory there should be no problem. Or, could the sensor affect engine performance by retarding the timing for example. Any info appreciated,
Old Jul 31, 2003 | 10:18 PM
bryant's Avatar
Default Re: Knock sensor code (Fardoche)
I think the knock sensor will put the cars ECU into limp mode (lower/no vtec, crappy gas millage, lower redline, basicly crap mode) Best is to just get a new one and do away with the code. Knock sensor is kinda pointless IMO, becuse if you have knock your GOING to hear it
Old Jul 31, 2003 | 10:29 PM
EF_LSVtec's Avatar
I ran my car for over 3000 miles with the knock sensor code on with no problems...I fixed it with a shielded wire and a brand new knock sensor installed in my b18 block...just had to retread a spot...
SpoonFedEj8
Dec 23, 2008 03:11 PM
ek4 sir civic
Jun 28, 2007 07:09 PM
b18cEF9
Dec 20, 2004 04:22 PM
smslude
Jan 14, 2003 10:37 PM
