What injectors to run with JRSC?
Old Jul 31, 2003 | 07:23 PM
LostLude's Avatar
Default What injectors to run with JRSC?
I have a Lude that is SC'd and I want some injectors. What are the right injectors for me? and Where can i get them for relatively cheap prices? (I'm try'n to get hondata soon as well)
Old Aug 15, 2003 | 04:19 PM
TOFU.man's Avatar
Default Re: What injectors to run with JRSC? (LostLude)
440's should do the trick and a hondata or SMC hack to tune them.
Old Aug 16, 2003 | 05:25 AM
GreddySi99's Avatar
Default Re: What injectors to run with JRSC? (B16AHondaSi)
90% of the supercharged lude people who run hondata use 550cc injectors your stock injectors are 290cc. If I had a lude it would get 550cc
Old Aug 16, 2003 | 07:40 AM
illi Adik's Avatar
Default Re: What injectors to run with JRSC? (intercooledJRSC)
440's/550's..depending on your goals.
Old Aug 16, 2003 | 09:01 AM
ChargedLude97's Avatar
550's if your going to go Hondata
Old Aug 29, 2003 | 02:38 AM
gSr_jB's Avatar
I have some RC 550 injectors if ineterested. letme know
Old Aug 29, 2003 | 08:10 AM
Old_Nocturnal's Avatar
The Jackson Racing Rising Rate Fuel Pressure regulator is a 5 to 1 ratio. I ran 60 psi static on my JRSC which is 95 psi at 7 pounds of boost (60 + (5 x 7) = 95). With minimal tuning on a VAFC I was able to get 12.1 air/fuel at the dyno. There is really no need to upgrade the injectors on a JRSC'd Prelude unless you are upgrading the pulley and making more boost. Sure, 95 PSI is a little hard on the injectors and the return line to the RRFPR, but it's nothing compared to the 12 to 1 Vortech I have on my turbo now at 9 PSI with a 45 psi static pressure 45 + (12 x 9) = 153 PSI!!! Still no leaks on factory injectors, but that is a little too much for me, so I am gonna upgrade the injectors with the turbo.
Old Aug 29, 2003 | 09:17 AM
DC2Slow's Avatar
***Hondata Dealer*** let me know if your interested
Old Sep 7, 2003 | 01:01 PM
Neukin's Avatar
Default Re: What injectors to run with JRSC? (DC2Slow)
im useing 380cc @ 10psi on b16
Old Sep 7, 2003 | 02:10 PM
hondamanwill's Avatar
440cc with Hondata. I'm getting my tuned Monday, I'll let you know how it goes.
Old Sep 7, 2003 | 05:08 PM
sharkcohen's Avatar
440s if you plan on staying at 6 psi. 550s if you would consider running 9 psi. Personally, I say just go with 550s since the latest hondata basemap was created on a JRSC lude with 550s.
Modified by sharkcohen at 6:18 AM 9/8/2003
Old Sep 7, 2003 | 08:49 PM
Blue-Civic-Hybrid's Avatar
Loved
I'm using RC 370's in my boosted GSR, running 6lbs of boost..works great!!
Old Sep 8, 2003 | 12:48 PM
DC2Slow's Avatar
Default Re: What injectors to run with JRSC? (Blue-Civic-Hybrid)
hey my shop is across from shawns dyno...where did u buy ur hondata from kevin?
B18 rider
Aug 8, 2008 10:51 AM
cleantegra
Feb 5, 2004 02:50 PM
B_1_8_hatch
May 6, 2003 08:02 PM
B_1_8_hatch
May 1, 2003 03:07 PM
MOGSR
Jan 26, 2002 08:00 PM
