... planning stages... - 12 sec - 50 state street legal - crx - ... on a budget...
Old Jul 31, 2003 | 06:07 PM
1.8T_EG's Avatar
Default ... planning stages... - 12 sec - 50 state street legal - crx - ... on a budget...
... lemme know what you think, if there is anything i should change, and if you have any suggestions... thanks...
<u>89 crx dx</u>
dpfi -&gt; mpfi
d16z6
<u>block</u>
turbopanda internals
blockguard
<u>head</u>
(suggestions for 9000rpm?)
<u>turbo kit</u> (which one? remeber, street legal)
greddy or apexi or hks
any others?
<u>fuel mgt</u>
dsm450
uberdata
<u>exhaust</u>
stock exhaust
electronic cutout
<u>suspension</u>
ground controls (500lb/in front, 700lb/in rear)
kyb agx shocks
jimfab traction bars
<u>drivetrain</u>
action clutch (which one?)
flywheel (which one, if any?)
itr lsd
<u>brakes</u>
(recommendations?)
<u></u>
Old Jul 31, 2003 | 06:14 PM
nevin's Avatar
isnt uberdata for obd1 ecus
Old Jul 31, 2003 | 06:31 PM
*Boostwerks*'s Avatar
Default Re: ... planning stages... - 12 sec - 50 state street legal - crx - ... on a budget... (1.8T_EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8T_EG &raquo;</TD></TR><TR><TD CLASS="quote">... lemme know what you think, if there is anything i should change, and if you have any suggestions... thanks...
<u>89 crx dx</u>
dpfi -&gt; mpfi
d16z6
<u>block</u>
blockguard
<u>head</u>
any others?
<u>fuel mgt</u>
dsm450
uberdata
<u>exhaust</u>
stock exhaust
electronic cutout
<u>suspension</u>
kyb agx shocks
<u>drivetrain</u>
itr lsd
<u>brakes</u>
(recommendations?)
<u></u></TD></TR></TABLE>
1. Change the shocks to Konis for those spring rates
2. I would see if you can run the Greddy kit but with the 18G
3. Make sure you use the GE block gaurd or no block gaurd at all.
4. The Action 1MD will be fine for your goals
5. I really like the new ACT flywheels and their nicly priced.
6. the ITR LSD will not fit in your tranny. Go with a Quaife.
7. I would do a 11" fastBrake kit for the with a Prelude master cylinder.
8. Because of the D series Geometry you should keep the revs below 8K. I don't know what company you should go with but at least put in springs/retainers.
That's all I can see right now.
Old Jul 31, 2003 | 07:02 PM
GSRswapandslow
Guest
Posts: n/a
he could EASILY convert his car to OBD1
Old Jul 31, 2003 | 07:06 PM
Turbocivic94's Avatar
U can go lsvtec or gsr with nos, hit 12's easy
Old Jul 31, 2003 | 07:07 PM
1.8T_EG's Avatar
Default Re: (nevin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nevin &raquo;</TD></TR><TR><TD CLASS="quote">isnt uberdata for obd1 ecus</TD></TR></TABLE>
... with the d16z6 swap and mpfi conversion, i will also be converting to obd1...
Old Jul 31, 2003 | 07:12 PM
1.8T_EG's Avatar
Default Re: ... planning stages... - 12 sec - 50 state street legal - crx - ... on a budget... (Bryson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson &raquo;</TD></TR><TR><TD CLASS="quote">
... thanks for all the input bryson!...
... so anyone know if the greddy kit is still carb legal if it uses the 18g vs the 15g?... thanks...
innes887
Aug 21, 2007 01:27 PM
EF_yo_89
10
Jan 23, 2006 03:09 PM
ineedacrx
Nov 14, 2005 12:14 PM
ed8racer90
Mar 20, 2003 10:00 PM
