ecu question
Old Jul 31, 2003 | 02:11 PM
goose12's Avatar
Default ecu question
i had recently swapped a b16 in my crx and the person who swapped it jipped me and put a single cam ecu....will a b16a ecu crank up the power of the motor?
Old Jul 31, 2003 | 06:45 PM
Esoterikos's Avatar
Default Re: ecu question (goose12)
are you sure the p28 has not been chipped? the sohc ecu will work just fine if it has been chipped.
Old Jul 31, 2003 | 07:31 PM
tianracerx's Avatar
yo im going threw the same thing im on my second swap cause the first one i got robbed by the swap and for mah new b16a i got a pm5 sohc ecu and i wanna know the same question but i called hasport they said it won't turn over what i heard is you can use a 90 93 integra ecu and get it chipped but im trying to find out if its tru
Old Jul 31, 2003 | 07:58 PM
Blaze45's Avatar
Brrraaaap!
Default Re: ecu question (tianracerx)
Dude if someone installed your swap with a PM5 how do you know that the rest of the swap is legit as for wiring n stuff? You can use the SOHC ECU, you just wont have VTEC. And if you cant have VTEC, whats the point?
Good Luck
Blaze
Old Jul 31, 2003 | 08:36 PM
poison's Avatar
Get a PR3 or PW0 ECU.
Old Jul 31, 2003 | 10:39 PM
goose12's Avatar
Default Re: ecu question (poison)
nah i have vtec but i wanna kno if the single cam computer is taking power in any way
Old Jul 31, 2003 | 10:46 PM
User 5426's Avatar
If it's not meant for your car I am almost guranteed that it will rob power. That is just my guess.
Old Aug 2, 2003 | 03:21 PM
tianracerx's Avatar
Default Re: ecu question (SeaQuake)
yea tru it prob takes power cause the fuel injection is diffreent just get a pr3 or pw0 what the point of doing a b16a swap if you don't have the v tec just go buy a pr3 look int he classifieds i go tmine for 150
Old Aug 2, 2003 | 09:26 PM
goose12's Avatar
thanks i will look for one
Old Aug 3, 2003 | 12:00 PM
Fabrik8's Avatar
Which ECU is it? If you already have a SOHC VTEC ECU, the cheapest thing to do would be to get it chipped with a DOHC program. Simple. This can be easily done in many cases.
Old Aug 4, 2003 | 05:02 PM
goose12's Avatar
Default Re: ecu question (Fabrik8)
its a pm6 but i thought i felt vtec when i drove it...guess not
Old Aug 4, 2003 | 06:06 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goose12 &raquo;</TD></TR><TR><TD CLASS="quote">its a pm6 but i thought i felt vtec when i drove it...guess not</TD></TR></TABLE>
Yes, look for an 89-91 B16A PR3 or PW0 ecu to gain full stock power from your B16A engine. The PM6 ecu is not a VTEC ecu at all, although, it will get you around town, but you're obviously not getting full potential from your engine using a PM6.
A PR3 is best to look for as if you plan to have the ecu reprogrammed later on the down the line, its easier to have chipped since there are more programs for it vs. the PW0 ecu.
Old Aug 4, 2003 | 07:19 PM
hondapwr's Avatar
You should be able to hear VTEC. mmmmmmmmbaaaaaaaa. If not, then you're probably not getting it.
P28, P30, P72 programs should all work fine for a B16. Just gotta tune the fuel.
Old Aug 5, 2003 | 04:26 PM
goose12's Avatar
Default Re: ecu question (Katman)
yea i figured that......thanks for all your'e help everybody...it is well appreciated
prelude208
May 9, 2009 08:13 PM
mengy007
Sep 29, 2005 05:48 PM
civicdragger818
12
Dec 31, 2003 08:32 PM
