Aftermarket Momo Wheel Installation (wiring)
OK....so the install of the wheel is pretty straight forward. Out with the old in with the new. So I unbolt the SRS reel and put the MOMO hub on, but how does the wiring of the horn work.
The Italian instructions aren't really helping because the way they have it wired, nothing works. So my question is how do I make ir work?
I checked all of the threads and for some cars it said I would need a metal shoe horn thing to contact the brass ring on the hub. Do I need to get this for my Integra? Also what wire do I connect to that piece of metal? I assume the white wire connects to the sho horn, but I'm not sure.
I swear I saw a how to before from this forum, but I can't seem to locate it.
Anybody with experience to share would be greatly appreciated.
Thanks in Advance
Thanks in Advance
The wire from the hub connects to the back for the horn button, if that's what you are referring to.
As for the shoe horn piece, yes you need it and you can buy it from Honda. Basically it's there to ground the back of the hub.
Well at least you got the right hub.... the hub Momo usully sells for the Integra has 3 spring loaded connectors on the back of the wheel. If you are having trouble with anything, IM me. I have helped many of H-Ters on this matter..... and I have some pics of the shoe horn too.
crdcz03
Sep 10, 2020 09:23 PM
