Nology Wires
Old Jul 31, 2003 | 01:51 PM
AWR19's Avatar
Default Nology Wires
Hey i already have a set of Denso Iridium spark plugs installed on my car, and i was wondering how they would work w/ those Nology Hot Wires. My cousin has those wires and he says they work well so i was considering getting a set of my own. Will they work at all or good w/ the aftermarket plugs i have now? R they even worth the money in ur oppinions?
Thanks
Old Jul 31, 2003 | 02:24 PM
2point6's Avatar
Default Re: Nology Wires (AWR19)
the wires work, but fitment is very poor. Stick with OEM or NGK.
Old Jul 31, 2003 | 03:04 PM
LostLude's Avatar
Default Re: Nology Wires (2point6)
I'm runn'n magnecors, they are pretty nice fitment is good and everything
Old Jul 31, 2003 | 03:05 PM
caLiH22A's Avatar
yea, just stick with NGK's, you cant go wrong.
Old Jul 31, 2003 | 06:02 PM
AWR19's Avatar
Default Re: Nology Wires (caLiH22A)
How much HP do u think u would get w/ NGK?
NGK is much cheaper in price than the Nology wire set, so is Nology just overpriced or does it really give u that extra HP or so that NGK doesnt?
Thanks
Old Jul 31, 2003 | 07:02 PM
H22 CD5's Avatar
ngk wires dont really add any hp at all. unless you really needed to replace them in the first place...then you will regain that lost hp you had when you were running around with the old wires.
I had a set of nology wires when i first had my h22 swap and i only kept them on there for a week and ripped them out for ngk's.there was no difference.i swapped out to the ngk's mainly because my engine looked ogly with those grounding straps hanging everywhere. i just wanted to put back that grey,plastic cover peice.
Modified by H22 CD5 at 4:25 AM 8/1/2003
Old Jul 31, 2003 | 09:56 PM
caLiH22A's Avatar
Default Re: (H22 CD5)
yea like H22 CD5, wires will not give you any HP increase that is noticeable, unless you did really need wires. but just stick to NGK's and everything will be fine.
Old Aug 10, 2003 | 07:23 PM
AWR19's Avatar
Default Re: (caLiH22A)
What is the life expectancy on Nology wires and NGK???
good for daily driving?
Old Aug 10, 2003 | 09:41 PM
musclefella's Avatar
Has anyone tried MSD wires???
Old Aug 11, 2003 | 03:46 AM
Shakes's Avatar
space cadet
Default Re: (musclefella)
check this out.
http://iwcweb.com/eclipse/html/warning.html
cliff notes: Hotwires use air as their capacitive dialetric. over a short ammount of time it breaks down and is worse then plain wires.
powerpuff
Nov 15, 2013 04:29 PM
firaga21
Oct 29, 2008 05:36 PM
abeaujuin
Jan 5, 2004 10:06 AM
SilverIntegra
Apr 2, 2002 08:32 AM
