Which side of this fitting is BSPT? It's a 1/8" bspt male to 1/8" npt male
Old Jul 31, 2003 | 10:11 AM
AcCO12D95's Avatar
Default Which side of this fitting is BSPT? It's a 1/8" bspt male to 1/8" npt male
I just got this fitting, and tthe only difference I can see is that one side is larger than the other side, but I wanted to know which side of the fitting to screw into the block?
Thanks
Old Jul 31, 2003 | 11:33 AM
AcCO12D95's Avatar
Default Re: Which side of this fitting is BSPT? It's a 1/8" bspt male to 1/8" npt male (AcCO12D95)
^bump^
Old Jul 31, 2003 | 11:35 AM
Kwuaymaikrup's Avatar
I would imagine whichever side fits in the block would be the one you use ...my experience showed the smaller one is the side to use. HTH
-Ryan
Old Jul 31, 2003 | 12:14 PM
AcCO12D95's Avatar
Default Re: Which side of this fitting is BSPT? It's a 1/8" bspt male to 1/8" npt male (Kwuaymaikrup)
yea, i just matched up the threads with a npt fitting. it is the smaller end that goes into the block...hopefully!
Old Jul 31, 2003 | 01:58 PM
bluebullet's Avatar
I believe bspt has a tapered end, that is the difference between bsp and bspt
Old Jul 31, 2003 | 03:55 PM
sparkz's Avatar
Default Re: Which side of this fitting is BSPT? It's a 1/8" bspt male to 1/8" npt male (bluebullet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluebullet &raquo;</TD></TR><TR><TD CLASS="quote">I believe bspt has a tapered end, that is the difference between bsp and bspt </TD></TR></TABLE>
thats correct. bsp(t) t is for tapered
Old Jul 31, 2003 | 04:08 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: Which side of this fitting is BSPT? It's a 1/8" bspt male to 1/8" npt male (sparkz)
Nobody said anything about BSP tho, the question at hand was bspt and npt. The block should be bspt, and the npt should go to the lines.
hasback*
Feb 15, 2007 01:30 PM
dornon13
Dec 27, 2005 01:20 PM
CA6VTEC
May 20, 2004 05:07 PM
ScottEK
Jul 31, 2003 07:56 PM
Bnjmn
Jul 4, 2003 04:27 PM
