synthetic vs regular oil
Old Jul 31, 2003 | 08:00 AM
bc_psychocivic's Avatar
Default synthetic vs regular oil
What kinda oil would u recomend.
Swapping in a DOHC ZC motor and pondering oil choices.
Old Jul 31, 2003 | 08:15 AM
APEX CRX's Avatar
Default Re: synthetic vs regular oil (bc_psychocivic)
I would use a regular oil to break in the motor then switch to synthetic
Old Jul 31, 2003 | 08:17 AM
guttedEF's Avatar
Default Re: synthetic vs regular oil (APEX CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by APEX CRX &raquo;</TD></TR><TR><TD CLASS="quote">I would use a regular oil to break in the motor then switch to synthetic</TD></TR></TABLE>
I'm sure this isn't a brand new engine. It's been broken in already. I'd use synthetic unless you have an oil leak, then I'd use either sonventional or one of the new High Mileage oils for older engines. Synthetic leaks fadter than conventional, if you were wondering.
Old Jul 31, 2003 | 09:17 AM
yes it is a used engine. all seals and gaskets etc will be swapped, but i am not planning on doing any internal work to the engine.
Old Jul 31, 2003 | 09:39 AM
Racer613's Avatar
Lovin' the SWEPCO
Old Jul 31, 2003 | 09:46 AM
raene's Avatar
I will touch nothing but synthetic
I ran dino oil for about 6 months to kind of clean it out and make sure it was in normal operating conditions, and then switched to synthetic. One thing you should note is that synthetic usually has higher levels of detergents in it, so for the first few oilchanges your oil will be black as pitch coming out. That's the synth detergents eating the poop off the inside of your engine so don't worry about it . I stuck with synth for over a year now and my oil on changing is now a nice light brown colour.
Synth makes it faster too
Old Jul 31, 2003 | 11:17 AM
2point6's Avatar
Default Re: (Racer613)
Swepco
Old Jul 31, 2003 | 11:23 AM
Ef Whore's Avatar
Default Re: (2point6)
I'm personally a fan of plain old Quaker State 5w-30, non-synthetic....never did me wrong, and it's what Honda suggests as oil for the life of the car. Then again I dont roadrace often, in that case a synthetic might be better.
Old Jul 31, 2003 | 11:39 AM
ATS*VEEE's Avatar
regular oil is fine, syntehic only once every 2-3 regular oil changes.........synthethic DOES NOT have detergents to clean ur motor out...regular oil does, if u open up a motor thats been babied with synthetic compared to regular oil, you will see that syn turns everything in the motor like brown stained colored......opposed to regular it has detergents to clean out the tiny tiny particles of metal bouncing around in your lovely motors....but then again.......i stand corrected.....synthethic=brown stained motors, reg=has detergents doesnt turn motor grimmy brown yellowish color....
Old Jul 31, 2003 | 11:52 AM
raene's Avatar
Default Re: (richierich)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by richierich &raquo;</TD></TR><TR><TD CLASS="quote">synthethic DOES NOT have detergents to clean ur motor out...</TD></TR></TABLE>
Oh really?
From Royal Purple's website:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Engine oils are formulated with a fine balance of additives (anti-foam, corrosion inhibitors, anti-wear, detergent / dispersants, oxidation inhibitors) and more is not necessarily better. The use of an oil additive could upset the balance resulting in reduced performance.</TD></TR></TABLE>
Old Jul 31, 2003 | 12:22 PM
ATS*VEEE's Avatar
i guess........but i do kno that syn does make motor stained brown- yellowed color........nasty looking.........
Old Jul 31, 2003 | 03:43 PM
EG8R's Avatar
Motul
Old Jul 31, 2003 | 04:32 PM
rice_classic's Avatar
Default Re: (mr. skelly)
I like to use bike chain oil because it works so well on my Huffy!
Old Jul 31, 2003 | 08:04 PM
VashTheStampede's Avatar
No tears. Only dreams, now.
Hahah... I just put synthetic blend in my B16... 10w30... .heavy as hell, but it does the trick.
deerman2701
14
Jan 11, 2012 07:58 AM
BB4
Sep 11, 2006 02:29 PM
gamblezhang
Jan 30, 2006 09:30 PM
old_school_dohcvtec
Feb 10, 2005 06:03 PM
95integrags-r
Apr 30, 2003 08:06 AM
