JDM H22 Distributor Direct Replacement
Old Jul 31, 2003 | 06:12 AM
asnsensasian's Avatar
Default JDM H22 Distributor Direct Replacement
If you damage a JDM H22 distributor, is there any direct replacement besides another JDM one? Search didn't help me much because no one seems to answer this question.
Old Jul 31, 2003 | 05:45 PM
aeolus's Avatar
Default Re: JDM H22 Distributor Direct Replacement (asnsensasian)
try moroso.they have replacements,and no core is needed..
Old Jul 31, 2003 | 06:25 PM
Default Re: JDM H22 Distributor Direct Replacement (aeolus)
sounds expensive..
Old Nov 27, 2003 | 08:14 PM
fastwanabe's Avatar
anyone know the answer to this one?
Old Nov 27, 2003 | 09:11 PM
aeolus's Avatar
Default Re: JDM H22 Distributor Direct Replacement (fastwanabe)
you can also try king distributor,i believe there banner comes on once in a while on here.
Old Nov 28, 2003 | 02:23 AM
Garrett's Avatar
USDM is direct fit
Old Nov 28, 2003 | 04:20 PM
fastwanabe's Avatar
Default Re: (Garrett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garrett &raquo;</TD></TR><TR><TD CLASS="quote">USDM is direct fit</TD></TR></TABLE>which year should I order to make sure it internal coil?
Old Dec 3, 2003 | 02:46 PM
fastwanabe's Avatar
Default Re: (fastwanabe)
anyone?
Old Dec 4, 2003 | 06:28 AM
1700anddroping's Avatar
alot of people don't know about this one ,so here it is.you can take the internals
out of a single ohc obd 1 and put them in any obd-1 dist.same as obd-2 also.i had a problem w/my h22 one time and tried it and it works perfect.if you want you can send it to me and i'll do it for you,just let me know.
Old Dec 7, 2003 | 02:11 PM
fastwanabe's Avatar
Default Re: (1700anddroping)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1700anddroping &raquo;</TD></TR><TR><TD CLASS="quote">alot of people don't know about this one ,so here it is.you can take the internals
</TD></TR></TABLE>actually I had tried this a little while back and it didnt work right. Me and my friend tried a different obd1 civic distributor on another H22 and it didnt work right either.
Old Dec 14, 2003 | 06:04 PM
fastwanabe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastwanabe &raquo;</TD></TR><TR><TD CLASS="quote">actually I had tried this a little while back and it didnt work right. Me and my friend tried a different obd1 civic distributor on another H22 and it didnt work right either.</TD></TR></TABLE>ok I was able to get the SOHC dizzy internals to work right... the secret is you must use the stock H22 shaft and it'll run like stock.
Old Dec 14, 2003 | 06:16 PM
boostn420's Avatar
I heard from a friend with an h22 accord that the internals for the accord will swap over for what you need.
Old Dec 14, 2003 | 06:17 PM
yeah! you must run the h22 center shaft,sometimes you might have to grind a little nub of the bottom of the center sensor so that it sits flat.i'm glad your up and running.
Old Dec 14, 2003 | 06:21 PM
and yes you can run after market ignition to with no problems at all.you should have known the center shaft from the sohc would not work as to number 1 cyclinder is in a different position.but hey now you know and so do alot of people now.
djsire
Sep 9, 2012 09:52 PM
friday86
Apr 11, 2007 11:46 AM
Built2.0Lude
Apr 20, 2004 01:47 PM
KGAccord
Mar 3, 2002 01:09 PM
