Turbo question (n00bie)
Old Jul 31, 2003 | 05:53 AM
CHK4TIX's Avatar
Default Turbo question (n00bie)
i have recently purchased a Fmax kit for the h22. (t3/t4) I purchased some DSM 450's, and i already have a vafc. So, i was planing on doing the hack until i have some more money to get a standalone system.
My question is, i have a jdm h22 and the cr is 10.6:1, (the usdm version is 10.1:1) I only plan on boosting 6 psi max (until i re-sleeve). Since this kit was made to run on the 10.1@9 psi , does it make a lot of difference that it will be on used on 10.6@6 psi?
If it does then how much would a .057" Cometic head gasket drop the cr?
If anyone has other opinions or options your comments are welcome
Old Jul 31, 2003 | 07:05 AM
platinum00's Avatar
Default Re: Turbo question (CHK4TIX)
so your plaining on running the afc hack at 6psi right.
i think you should be fine. the compression is a little high. but as long as your a/f is good and your not detonating i think your good.
as for the head gasket, i think it drops it half point. which would take you right back to the 10.1
platinum
Old Jul 31, 2003 | 08:44 AM
CHK4TIX's Avatar
Default Re: Turbo question (platinum00)
thanks platinum00, thats what i figured. Is just good to here it comming form someone else.
Old Aug 3, 2003 | 12:22 PM
CHK4TIX's Avatar
Turbokid13
Jan 8, 2005 04:04 PM
GoodFella
Aug 13, 2003 08:25 PM
CHK4TIX
Jul 30, 2003 03:00 PM
dominate9
Dec 24, 2002 12:39 PM
The Punisher
Aug 16, 2001 10:00 PM
