Going From 81mm to 83mm, which Headgasket?
Old Jul 31, 2003 | 05:26 AM
FredoSP's Avatar
Default Going From 81mm to 83mm, which Headgasket?
Quick Question guys,
I'm going with a bigger bore from 81mm to 83mm, and I was wondering if I should use the OEM headgasket and make it bigger or just go with an 83mm headgasket from Golden Eagle or something.
Please post your suggestions/or what you have personally went with that works.
Thanks - Fred
Old Jul 31, 2003 | 05:46 AM
DaveF's Avatar
Default Re: Going From 81mm to 83mm, which Headgasket? (FredoSP)
that is all that GE does. they take stock gaskets and modify them. they also machine out the dowl pin holes for lsvtec conversions.. we have a ls vtec but we are using a vtec head gasket with it.
Old Jul 31, 2003 | 06:09 AM
FredoSP's Avatar
Default Re: Going From 81mm to 83mm, which Headgasket? (2.2Lcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.2Lcivic &raquo;</TD></TR><TR><TD CLASS="quote">that is all that GE does. they take stock gaskets and modify them. they also machine out the dowl pin holes for lsvtec conversions.. we have a ls vtec but we are using a vtec head gasket with it.</TD></TR></TABLE>
so what your saying is that OEM and GE are equally as good, but the GE is more plug and play and the OEM might have to be slightly modified?
Old Jul 31, 2003 | 06:13 AM
Arturbo's Avatar
Better than steak
25 Year Member
What I recomend is this: Since the OEM gasket had .003" fire ring and if you modify it to a 83mm bore then you take that fire ring out. So if you are getting your engine sleeved get the sleeves raised .003" to compensate for what was cut out of the gasket.
Just curious fred, why do you call me and ask me the same question then post the same exact same thing?
Old Jul 31, 2003 | 06:31 AM
FredoSP's Avatar
Default Re: Going From 81mm to 83mm, which Headgasket? (Arturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">What I recommend is this: Since the OEM gasket had .003" fire ring and if you modify it to a 83mm bore then you take that fire ring out. So if you are getting your engine sleeved get the sleeves raised .003" to compensate for what was cut out of the gasket.
Just curious fred, why do you call me and ask me the same question then post the same exact same thing? </TD></TR></TABLE>
I forgot what u said, and I figured u were sleeping at this hour
Not to mention we always get side tracked on the phone. Either you hear the ice cream man driving by my house or I tell you some irrelevant story that has nothing to do with anything, lol.
P.S. Ill call you later
Old Jul 31, 2003 | 12:18 PM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FredoSP &raquo;</TD></TR><TR><TD CLASS="quote">P.S. Ill call you later</TD></TR></TABLE>
love birds?
Old Jul 31, 2003 | 01:59 PM
FredoSP's Avatar
love birds? </TD></TR></TABLE>
haha nah, Art's a good guy that takes the time out to answer any FI question I got, or questions.
ls_bitik
Jul 9, 2007 08:54 AM
Chugger
Mar 20, 2007 09:30 AM
SPOOLINmatt
Feb 7, 2006 07:28 PM
Bigjussin
11
Apr 16, 2005 02:57 PM
tunedek
Feb 26, 2005 12:01 PM
