started turbo install: ?'s Reg. VAFC install and turbo/manifold bolts.
Hey guys, i've begun my turbo install on the SOHC.
I was wondering if there are any special kind of bolts I should get to bolt the manifold to the turbo.
ALSO how did you wire your VAFC into your ecu. I have a P28 ecu and wondering how you attached it. Do u need those clips that Apexi shows on the site?
Thnaks
Dan
Thnaks
Dan
I went there and saw the clips, but it showed them hooking it up with those damn clips. Where do i get those things?
(yeah i went there b4 i asked this
) I saw the WH-1 which is how i hook mine up. Basically I was wondering about the clips
Thanks
) I saw the WH-1 which is how i hook mine up. Basically I was wondering about the clipsThanks
lucas569
Jul 15, 2002 09:57 PM
