Spark plug torque
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kruthles »</TD></TR><TR><TD CLASS="quote">yep looks like 13/14 ft/lbs, thanks for the help guys</TD></TR></TABLE>
So this would go with the B18C1 to correct?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluemex »</TD></TR><TR><TD CLASS="quote">are there any down sides for having it too tight</TD></TR></TABLE>
Could break
Could break
more likely, if to tight, it could strip out the spark plug hole in the head.
also, if not tight enough, you stand the chance of it loosening up.
properly torquing the spark plugs is a very important aspect which many neglect.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kkim »</TD></TR><TR><TD CLASS="quote">
properly torquing the spark plugs is a very important aspect which many neglect.</TD></TR></TABLE>
I agree. My brother didnt tighten his up enough and they loosened up on him. Car ran like **** and he asked me to come over...I opened his hood and could tell one of the plugs had loosened b/c his wire was up about a half inch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soup **** »</TD></TR><TR><TD CLASS="quote">would be the same.
13/14 ft lb torque = hand tight with me
It is about hand tight; if the plugs have been torqued down before (such as if your checking the plug condition)
But, if the plugs are new; you will need to crush the washer which will be more than hand tight.
</TD></TR></TABLE>It is about hand tight; if the plugs have been torqued down before (such as if your checking the plug condition)
Evs-One
Apr 16, 2003 05:47 PM
