Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
It's 10:45 p.m....do you know where your motor is....???
Old Jul 30, 2003 | 06:46 PM
FAST4DR's Avatar
Default It's 10:45 p.m....do you know where your motor is....???
I think we can...I think we can...
VIR or bust...!!!
Old Jul 30, 2003 | 06:49 PM
XR4racer's Avatar
Default Re: It's 10:45 p.m....do you know where your motor is....??? (FAST4DR)
As long as it's not VIR ...and then BUST ...all over the track
Keep at it! I expect to see you in the paddock Fri evening.
Old Jul 30, 2003 | 06:58 PM
Warren's Avatar
Wrong-Way Wang
My car is Flintstone powered right now. I feel your pain. How many hours left do we have?!?!
Warren
Old Jul 30, 2003 | 07:00 PM
FAST4DR's Avatar
Hmmm...something(s) is(are) missing...I think we'll be ok once we find it...
Modified by FAST4DR at 9:16 PM 7/30/2003
Old Jul 30, 2003 | 07:01 PM
Back in Black's Avatar
Rather OG
You better be here by 7 tomorrow, Chad. We need some sleep
Jason-
who never thought moving into a house could be such a pain.
Old Jul 30, 2003 | 07:29 PM
Warren's Avatar
Wrong-Way Wang
You need a pair of these. They're going in my car. I'll let you guess the duration and lift.
Warren
Old Jul 30, 2003 | 07:43 PM
Dan GSR's Avatar
Default Re: It's 10:45 p.m....do you know where your motor is....??? (Jason Franza)
looks good Dave
how u planning on breaking in the motor for this weekend?
or just break it in at the track?
Old Jul 30, 2003 | 07:44 PM
BlueR's Avatar
Default Re: It's 10:45 p.m....do you know where your motor is....??? (Dan GSR)
can we not use the word "break"
Old Jul 30, 2003 | 08:19 PM
FAST4DR's Avatar
Default Re: It's 10:45 p.m....do you know where your motor is....??? (Warren)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Warren &raquo;</TD></TR><TR><TD CLASS="quote">You need a pair of these. They're going in my car. I'll let you guess the duration and lift.
Warren
ITRRRRRRRRRRRRRRRRRRRRR...actually, you are only partially correct, Warren...there is much more missing...which explains why you see Chad in pic 1 using a grindeRRRRRRR....long story short...valves cut in too deep...so we have to modify rocker aRRRRRRms.
And, yes, let's not use the word BREAK...
Hopefully, she breaths tonight...
Old Jul 30, 2003 | 08:44 PM
smokin rubber's Avatar
What your not done yet
Old Jul 30, 2003 | 11:04 PM
chad's Avatar
Moderator
Default Re: (smokin rubber)
it's 255 am......engine is done....car runs.....drove it home tonight....hit vtechk a couple of times.....car was done at 2 am......so to recap my day
10 am.....ENGINE IN PIECES.....
1230pm head is together and on block
4pm....engine is in car.....
530pm start car.....fire, fuel.....no starty.....
1100pm....pull rocker arms out one more time.....
1200am still grinding on rocker arms.....
1 am.....adjusting valves for the 5th time today....hmmmmm...there's actually clearance there.....NICE.....look at dave and say.....it will run this time!!!
130 everything bolted down.....turn car over.....VRRRRRRRRRRRRRRRRROooooOOOOOOOOOOOOOOOOOM mmMMMMMMMMMMMM
now 3 am........
to make long story short
valves were cut TOO FAR INTO THE HEAD!!!! which LEFT NO CLEARANCE ROOM TO ADJUST VALVES.....
rocker arms were hitting retainers.....valve adjustment lashes couldn't get loose enough.....we fixxed it....it is running.....
such a relief.....and the benefits of hard work.....to think on tuesday we HAD NOTHING FOR THE ENGINE&gt;.....block wasn't even here yet......wooo hoooo.....
thanks
DAVE
DANIEL
JOEL
GREG
for your help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
see you at the track for this months GFCP addiction......
Old Jul 30, 2003 | 11:05 PM
chad's Avatar
Moderator
Default Re: (chad)
oh yeah....james and whitaker you didn't pay UPS enough to loose the block!!!! hehehe....they only lost it for 5 days!!!! boo yaaaa
Old Jul 31, 2003 | 12:08 AM
kedwards's Avatar
Very good, Chad.
We assembled my replacement engine Saturday, and instaled it.
Didn't get it to start until Tuesday night (replaced the starter). I was quite relieved when it fired, on the first crank.
BTW, this is what the previous engine looked like after Summit
http://webpages.charter.net/k....3.JPG
There were also 2 smaller holes in the block on the othter side... Con rod in *many* pieces, and very little left of the #4 piston...
Old Jul 31, 2003 | 12:27 AM
Shaun K's Avatar
Default Re: (chad)
Good luck at VIR this weekend Chad. Kudos on the quick turnaround...We know the pain
Old Jul 31, 2003 | 03:10 AM
urbanlegend21's Avatar
New User
Default Re: (Shaun K)
I woke up this morning at Corey;s house at 5:45 and where was he? Outside underneath the Accord putting the new exhaust and header on.
Thanks Corey and Dave @ SMSP, they worked at all night to get my $100 header and exhaust almost perfect
Morgan - who now drives an Accord with 10-15 extra HP hopefully
Old Jul 31, 2003 | 06:33 AM
FAST4DR's Avatar
Default Re: (urbanlegend21)
3 RedBulls $5.67
1 R&D Race Prepped B18 $7500
Grinding Rocker Arms after 1am, Pricele$$
Glad its done...and tired. See you all tomorrow!!
Old Jul 31, 2003 | 07:02 AM
Hunter's Avatar
Default Re: (FAST4DR)
awesome, lookin' forward to seeing ya'll run (not smoke)
Old Jul 31, 2003 | 08:00 AM
speedracer33's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FAST4DR &raquo;</TD></TR><TR><TD CLASS="quote">1 R&D Race Prepped B18 $7500</TD></TR></TABLE>
B18?!? You moved up, huh?
Matt
Old Jul 31, 2003 | 08:08 AM
Mike P.'s Avatar
25 Year Member
Default Re: (speedracer33)
It seems the ante has been upped in H1 for the second season. Is this motor an upgrade to what was in there before?
Old Jul 31, 2003 | 08:20 AM
FAST4DR's Avatar
Default Re: (Mike P.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike P. &raquo;</TD></TR><TR><TD CLASS="quote">It seems the ante has been upped in H1 for the second season. Is this motor an upgrade to what was in there before?</TD></TR></TABLE>
B18C pre dropped valve and same setup now. A bit more CR this time...we should pick up a few ponies...
Old Jul 31, 2003 | 11:41 AM
BlueR's Avatar
Default Re: (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">it's 255 am......engine is done....car runs.....drove it home tonight....hit vtechk a couple of times.....car was done at 2 am......so to recap my day
now 3 am........
thanks
DAVE
DANIEL
JOEL
GREG
see you at the track for this months GFCP addiction......</TD></TR></TABLE>
no love for the yankee up north who donated his pistons
Old Jul 31, 2003 | 12:46 PM
FAST4DR's Avatar
Default Re: (BlueR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">
no love for the yankee up north who donated his pistons </TD></TR></TABLE>
Well, in my book, pistons equate to donating a kidney, so....
thank you, Marc, for your overbores!
Also, a HUGE thanks to Scott, Bob and the crew at King Motorsports. We'll put that ZEX kit to good use!!!!
Old Jul 31, 2003 | 01:30 PM
Ferrell's Avatar
nice..... cant wait to see it in action this weekend
Old Jul 31, 2003 | 01:37 PM
XR4racer's Avatar
update... the The Motor has made it to Charlotte.. Chad continues on his voyage.. towards VIR. Me...I'm still stuck at work for a little while.
Old Jul 31, 2003 | 03:59 PM
Dancing is Forbidden's Avatar
Default Re: (XR4racer)
Glad to hear it started up last night. I hate having a job, would have been up there otherwise. oh well. Good luck this weekend guys.
Machinehead115
Oct 22, 2007 10:39 AM
Nikos
77
Jun 25, 2005 07:21 PM
sittin on GOLD
Nov 18, 2004 07:20 PM
B18CXr
11
Jul 23, 2003 06:20 AM
Stinkycheezmonky
Apr 3, 2003 05:58 AM
