d-series turbo, How much hp?
heres the deal: I have a 93 civic hatch back. I swapped in a sohc vtec ( wasn't an si) and now want to turbo it. If I sleeve and go all out on a sohc vtec what is the most hp I can expect to get? I am looking to stay around the 400 range,am I dreaming with a sohc and how stupid would I be doing all this work on it?
400whp? Those are some lofty goals!
I'm not going to say that it's *impossible*. But it will definitely be difficult.
300whp is do-able (and done before). Anything more and you'll need deeper pockets. :D
Guest
Posts: n/a
honestly...you'd just be better off swaping.
I'm in the middle of a d sereis turbo setup...but i'm going to go BACK to another b seires soon.
BUt, if you do go all out on this....and make that much HP, hell 350+; and I'll shake your hand cause you'd be a HARDCORE NINJA ************, am i right folks???
Blah,
Its very possible you guys.
I'm going for 350-400+hp as well.
My spare block will be sleeved with my CP pistons/Pauter Rods (soon, just sold my Eagle's)/ARP headstuds/ACL bearings/Hondata S200B etc...
Just Go with a nice 60trim T3/T04e Turbo, big injectors, and big boost.
I think BoostedHybrid is shooting for some big numbers as well
SOHC's own,,,they're a dime a dozen if you blow something, unlike the B series.
Goodluck if you are serious about it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ill_take_one »</TD></TR><TR><TD CLASS="quote">Blah,
doing the same here
GE sleeved block, JE 77mm pistons, and *gasp* Eagle rods
doing the same here
400whp is easily obtainable. You have to plan out exactly what you want out of your engine to create the power level you are after. I am shooting for over 300whp on pump gas, which I think will easily be obtainable. I'll know within three weeks. I personally love the fact that the parts are cheap, easily sourced and can make big power if the envelope is pushed enough. Also the aftermarket is starting to support the d-series more. My girlfriend has around 5K in her set-up, but she is still 3-4K cheaper than building a b-series. Compariably I have around 8K in my b-series set-up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ill_take_one »</TD></TR><TR><TD CLASS="quote">SOHC's own,,,they're a dime a dozen if you blow something, unlike the B series.
Not SLEEVED SOHC's.
BTW, how much was sleeving for your D? I might just drop this whole B-series hunt and buildup what I have now.
Not SLEEVED SOHC's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98CTRCoupe »</TD></TR><TR><TD CLASS="quote">
Not SLEEVED SOHC's.
Well no doubt
Most sleeving goes from about $750-1000+. Thats not including the installation of pistons/rods/bearings/headstuds/etc..
CivicRyda2k, The only reason I sold my eagles, is because i bought them used. I finally realized that it wasnt worth the risk to put them in my soon to be sleeved block. Mainly because i DONT know what these rods really went through. So why cheap out on rods, when i haven't cheaped out on anything else, ya know?
I may buy some new Eagles, but only if i get the upgraded rod bolts
To civicryda2k and boostedhybrid, which turbo do you plan on running in your setup?
I'm still unsure if i should go with the 57 or 60 trim, .48 A/R exhaust, .63 A/R intake.
Not SLEEVED SOHC's.
Well no doubt
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ill_take_one »</TD></TR><TR><TD CLASS="quote">I'm still unsure if i should go with the 57 or 60 trim, .48 A/R exhaust, .63 A/R intake.
Bigger is better.
How about those Precision turbos that everyone's raving about? What's a good size for our little SOHC wonder blocks?
</TD></TR></TABLE>Bigger is better.
Bigger is better.
SC57 should be good for low 300's with a little lag. Anything more than that on the D-series from precision and you'll probably want to look into the the SC34 but the lag/hp trade off will deffinently be more noticeable. Working on a new setup and still debating if I want to go Precision or not.
Bigger is better.
</TD></TR></TABLE>SC57 should be good for low 300's with a little lag. Anything more than that on the D-series from precision and you'll probably want to look into the the SC34 but the lag/hp trade off will deffinently be more noticeable. Working on a new setup and still debating if I want to go Precision or not.
i have a stock internals sohc d16y8, i had a turbonetics t3/t4, and the turbo blew...i bought a precision turbo from arturbo, just installed it, going to dyno the car soon.....
heres the details of the turbo.....Precision SC50 t3/t04e t3 w/.48 ar, turbine 69trim; compressor 50trim
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tur*bLu »</TD></TR><TR><TD CLASS="quote">Bump for current D series Turbo Builders...</TD></TR></TABLE>
they can't stop us and our econoboxes!
I have a friend that has a 97 ex with the d16y8 turboed with a T3/T4 and fmic. FMAX Kit. and on the dyno she hit 235hp to the wheels. She is fmaxturbochic and yes she is on this site too. All she did to hte block was a block guard, and head gasket. So go kill some dohc's, but be carefull of the mighty eclipse gs-x
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpydermanGS-T »</TD></TR><TR><TD CLASS="quote">I have a friend that has a 97 ex with the d16y8 turboed with a T3/T4 and fmic. FMAX Kit. and on the dyno she hit 235hp to the wheels. She is fmaxturbochic and yes she is on this site too. All she did to hte block was a block guard, and head gasket. So go kill some dohc's, but be carefull of the mighty eclipse gs-x</TD></TR></TABLE>
hey you!!!!
you changed your name? i got 215hp to the wheels, and now im using a precision t3/t4.......
gsx? huh?? i thought you were gs-t? lol, watch out???? muahahahahahahahaha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NA CRX Si »</TD></TR><TR><TD CLASS="quote">how about a t3/t4 with a 50 trim and .63AR. what can be accomplished with that? also what manangement are you using? would a zdyne fit the bill?</TD></TR></TABLE>
are you asking me about the mgt? if you are...i have 2 extra lucas injectors controlled by an mf2. I have a 2mm headgasket.
and tuning, tuning, tuning, took it to get dyno'd and had everything tuned there
check out precisions website http://www.precisionte.com/
and also if you have more questions about the precision turbo's i recommend no one else but Arturbo, he's da man!!!
hey you!!!!
Hey Spiderman whats up I have not heard from you in a while,, Let me give them some spidey sense. I think your kidding about how hard it is to make a d16y8 have 400 right! Dude Our Dual Purpose car(fmaxturbochics) which is ours I am married(but thats not important right now) is already putting out 220 hp with horrible tuning. With good tuning and a good exhaust its a 2/ 1/4 now should be about 240-250HP on 14 psi on a stock bottom end, so figure at least double that on a built motor and 20+psi of race gas.. Just thought I give you some backup on that...........
Modified by Nissmaxx at 3:40 PM 8/1/2003
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98CTRCoupe »</TD></TR><TR><TD CLASS="quote">Bump for my new found interest in D-series powa!
Anyone with a SOHC even running a Precision turbo? Or do I have to be the first?
Precision sc32 on a custom kit here, d16y8
</TD></TR></TABLE>Precision sc32 on a custom kit here, d16y8
