Running AC in a bseries swap
Old Jul 30, 2003 | 04:47 PM
Sohc Driver's Avatar
Default Running AC in a bseries swap
Whats up guys...I have a b18b swap into my 2000 civic...and its been damn hot running without AC..with my swap..i was given the b18b AC compressor....is there a way to run AC with my civic condenser without having to invest in a civic Si AC bracket. My idea was to run 2000 civic Si AC hoses and keep the b18b AC bracket....would this work?
Khoi
Old Jul 30, 2003 | 07:32 PM
Default Re: Running AC in a bseries swap (Sohc Driver)
bump..
Old Jul 30, 2003 | 11:42 PM
hondatool's Avatar
its should work..i thought all b series parts where compatiple...
Old Jul 31, 2003 | 06:21 AM
Default Re: (hondatool)
anyone else?
Old Jul 31, 2003 | 08:33 AM
Trey's Avatar
25 Year Member
Default Re: (Sohc Driver)
Don't be a cheap a$$!
In order to use your Civic compressor on a B motor, you NEED the P54 bracket.
If you want to use the B compressor on the B motor, you'll need the lines swapped and the system recharged.
Either way it's $100.
Just get the Si bracket and do it the right way.
38930-P54-000 $94.82 from http://www.hparts.com
Old Jul 31, 2003 | 12:17 PM
Iamhonda's Avatar
If you dont mind..can you tell me what year is your B18B motor?
Old Jul 31, 2003 | 01:05 PM
SpoonFedHatch's Avatar
here's my $20 solution to your problem.....USE the teg compressor, then buy (junkyard) a HIGH SIDE HOSE from a teg or civic si.....just follow the directions IN THE SECOND PIC!! THE TOP VERSION DOES NOT WORK!
https://honda-tech.com/zerothread?id=499176
Old Jul 31, 2003 | 03:35 PM
Default Re: Running AC in a bseries swap (NOGOEX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOGOEX &raquo;</TD></TR><TR><TD CLASS="quote">If you dont mind..can you tell me what year is your B18B motor?</TD></TR></TABLE>
2001
Old Jul 31, 2003 | 03:36 PM
Default Re: (Trey)
it will cost me more if i decide to invest in an AC bracket...almost 100 bucks for the bracket alone..and then i'll still have to get the AC unit charged....if i go for the AC line..it will cost me 50 bucks...and have to of course get my AC charged...getting the AC line alone is cheaper....
hondab1015
Jun 26, 2015 07:46 AM
mikester1222
Oct 29, 2007 06:10 PM
swappedcx
Mar 29, 2007 11:09 AM
racer_X_123
Jun 30, 2006 08:25 PM
