in need of a few torque specs
Old Jul 30, 2003 | 04:38 PM
slowazzhatch's Avatar
Default in need of a few torque specs
what are the specs for the water pump on the motor, and the oil pump also,
what about the tensioner for the timing belt?
crank pulley?
anyone know these - i cant find them anywhere online
TIA
Matt
Old Jul 30, 2003 | 05:55 PM
poison's Avatar
Default Re: in need of a few torque specs (slowazzhatch)
water pump 10 lbs I believe, same with oil pump, not very tight at all.
Tensioner I believe is 40 lbs not 100%
for the crank pulley, 130 ft-lbs.
Old Jul 30, 2003 | 06:36 PM
mmuller's Avatar
Mad Scientist
Default Re: in need of a few torque specs (poison)
water pump: 104 in-lbs
oil pump: 6mm bolts:96 in-lbs/8mm bolts:17
tensioner: 40 lbs
crank:130 lbs
hatchdrvr
Jan 26, 2007 04:08 AM
91tegrals
Jan 16, 2004 04:13 PM
