Misfiring w/ Greddy Blue Box
Old Jul 30, 2003 | 03:42 PM
ModlesSI's Avatar
New User
Default Misfiring w/ Greddy Blue Box
I have a Greddy kit for the 99-00 SI running @ 5.5psi intercooled. Running NGK BKR7E Plugs gapped @ .030... Would a different gap help? Have had the kit on for 3000 miles, and has been misifiring in all cylinders more frequently lately. Timing is set 1 degree below stock. Do other Greddy B series guys experience random misfiring w/ the blue box? or is it just me? Please let me know your experiences. Thanks.
Old Jul 30, 2003 | 04:03 PM
trunks1001's Avatar
Default Re: Misfiring w/ Greddy Blue Box (ModlesSI)
i had the same problem for my '00 si. code 71,72,73,74. i rechecked my wiring and checked for any leaks or anything. i couldn't find anything too. I then threw the box and put in a hondata and all misfiring went away.
Old Jul 30, 2003 | 04:31 PM
blacksi-t's Avatar
HEY BRO DONT FEEL BAD , I HAVE YOUR SAME SET UP 6PSI BLUE BOX ON MY SI
AND THIS STUPID P300 MISFIRE CAME ON TOO. I CANT WAIT FOR HONDATA
Old Jul 30, 2003 | 05:00 PM
ModlesSI's Avatar
New User
Default Re: Misfiring w/ Greddy Blue Box (blacksi-t)
Cool, even when it throws the code.... the car drives fine.. weird.
Old Jul 31, 2003 | 06:12 PM
ModlesSI's Avatar
New User
Also, it only happens @ idle.... rarely when driving in vaccumm while accelerating, but never @ WOT. Any other ideas? Would a Walbro pump help. I did notice however when i retarded the timing 3 degrees, it did not throw this code, however it would overheat more often. What timing are you guys running @ 5.5psi?
Old Jul 31, 2003 | 06:18 PM
APEX i GSR's Avatar
nope running a Walbro pump will not help
the only thing i've seen help is taking out the blue box injectors and running the stock injectors with an FMU setup & a missing link
or Hondata
Old Jul 31, 2003 | 06:49 PM
platinum00's Avatar
Default Re: Misfiring w/ Greddy Blue Box (APEX i GSR)
check your gap. set it to .28 and that should help.
are you running stock plugs. try 1 notch colder.
platinum.
Old Jul 31, 2003 | 06:59 PM
ModlesSI's Avatar
New User
Default Re: Misfiring w/ Greddy Blue Box (platinum00)
I'm using NGK BKR7E Gapped @ .030 I'll try .028 gap, thanks.
Old Jul 31, 2003 | 08:02 PM
blacksi-t's Avatar
****, my car is running so rich that burn my o2 sensor. wtf
Old Jul 31, 2003 | 08:30 PM
spooned out's Avatar
also have 99-00si greddy kit, I went with colder NGK plugs no missfires but car idles low, can't seem to get it to idle steady enuff to set the timming on it.
Old Jul 31, 2003 | 08:40 PM
ModlesSI's Avatar
New User
Default Re: (spooned out)
hrm,
Spooned Out - What kind of gap are you running on your plugs?
Old Aug 2, 2003 | 10:47 AM
the gap i was told is allready set when you buy them new from NGK so i just threw it in, no missfires but im running really lean for somereason (no good)
orangina
Mar 11, 2006 12:28 PM
Bimmerman
May 6, 2005 04:30 PM
dynamicRacing719
Jan 17, 2005 06:15 PM
Honda-Hooligan
Oct 28, 2003 08:34 PM
Pfieff
Aug 17, 2003 06:00 PM
