OS CTR piston/cylinder bore...
Old Jul 30, 2003 | 12:22 PM
granada_sun's Avatar
Default OS CTR piston/cylinder bore...
How much should the cylinders be bored out for OS .25 CTRs?
Old Jul 30, 2003 | 12:45 PM
1_bad_EF's Avatar
Default Re: OS CTR piston/cylinder bore... (granada_sun)
ummm maybe 81.23mm then the honing takes the remaining .02mm to get .25mm oversize. give your pistons top the machine shop and have them number them accordingly.
Old Jul 30, 2003 | 02:07 PM
If its bored out to the exact size of the pistons, the rings will get smoked won't they?
I just want to know what to tell the shop in case they ask, pretty much all their work is domestic but pistons are pistons i guess.
Old Jul 30, 2003 | 02:35 PM
1_bad_EF's Avatar
Default Re: (granada_sun)
I forget what the piston to cyl wall clearance is supposed to be but just give that and the pistons to a shop and they should have enough intelligence to figure it out(even though they work on V8's )
Old Jul 30, 2003 | 04:56 PM
1 2 NV's Avatar
each 1/4mm is .010 in inches. u will want about .0025" piston to wall clearance.
Old Jul 30, 2003 | 05:31 PM
thanks fellas.
Old Jul 30, 2003 | 11:16 PM
fox297's Avatar
CTR pistons can handle pretty tight clearance since the skirts are coated. Make sure you give them the rings and tell them to check for end-gap tolerance.
Old Jul 31, 2003 | 12:03 AM
I thought only ITR's were coated......???
Old Jul 31, 2003 | 12:04 AM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by granada_sun &raquo;</TD></TR><TR><TD CLASS="quote">I thought only ITR's were coated......
ctr's too
Old Jul 31, 2003 | 12:09 AM
sweeeeet...
Chief Wenceslaw
Mar 18, 2006 11:20 AM
diM.
Dec 19, 2004 02:51 PM
Almost
Aug 8, 2003 05:07 PM
RICHJ
Apr 15, 2003 06:58 AM
95gsr
Jan 16, 2002 06:56 AM
