ground control spring rates question - 350/400 or 400/350?
Old Jul 30, 2003 | 12:08 PM
Boofster's Avatar
Default ground control spring rates question - 350/400 or 400/350?
What exactly is the difference between having the higher rate be on the front or the rear? 350/400 vs. 400/350?
I looked around and seems most people like either one of those two. Is ride quality more dependent on the rear?
I am assuming that having the front stiffer will give you less understeer...right?
Old Jul 30, 2003 | 12:25 PM
jonsteR's Avatar
Default Re: ground control spring rates question - 350/400 or 400/350? (Boofster)
Higher spring rates in the rear will give you more oversteer.
SNsLude
Dec 21, 2004 06:00 PM
SNsLude
Dec 18, 2004 11:21 PM
PrinceAli132
Jul 19, 2004 06:17 PM
Toadfart
Jan 22, 2004 01:42 PM
