ok motor doesn't even crank.. where can i start looking?
after putting the b18c1 into a eg.. it fired up once and spit out fire but now it doesn't even crank.. where can i start looking? i checked all the fuses...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra_Boi »</TD></TR><TR><TD CLASS="quote">it fired up once and spit out fire</TD></TR></TABLE>
Spit fire? What do you mean?
Obviously on a car that doesnt start, the starter could be the problem. Take a look at the starters solenoid with a test light while someone is trying to crank the engine.
You got to give us some more details than that about what hapenned.
Fred
Fred
sorry about it.. after the motor was in.. my friend cranked it and it started up and was shooting fire out of the exhaust..a day later.. tried to start it.. nothing is even cranking.. i checked fuse/battery and somewhat of the starter.. i ran direct power from the battery to the starter and it made no difference.. starter wasen't getting any power..
along with the starter check for spark and fuel...if you arent getting those it aint gonna fire...if you have these how is your compression?????
How do you want him to test compression if the engine is not even cranking?
Integra_Boi: Just to make sure, by cranking, you mean cranking, not starting, right?
If you plugged the plugs wires in the wrong order, this could have caused some backfiring, and maybe if an injector was stuck open it could've gone up to spitting fire... I imagine..
Does the starter solenoid click like its trying to start? You gotta get to know if the starter is working, and then you can check if the engine is stuck.
If you want to try turning your engine by hand to know if it's not blown, you can remove the front left wheel and use that hole that lines up with the crank pulley bolt to crank the engine with a ratchet (in neutral of course).
Have you tried pushing it and then starting it on compression?
give us some news..
give us some news..
check the spark plug wires to make sure they are in the right order....
check spark plugs
actually just check the who ignition system
check spark plugs
ok guys its up and running.. the dude that yanked the gsr from the crashed car apparently messed up the wires.. and just randomly put them back in the holes.. what a ....
Thanks for you guys help.. the only thing left now is vtec wires but he's driving around..
porkchop14
Sep 28, 2004 09:10 AM
