clear this up real quick (HCP mounts)
my hcp mounts on my eg dont "look fitted." the mounts fit real tight onto the eg mounts, and i had some trouble trying to fit everything in, so it came to the point where you just wanna get that **** in. well i did, but the polyurethane bushings on the ends are kinda bent on the two front mounts. the side bushings on the front transmission mount is kinda gapped and the driver side mount's bushing looks smushed against the mount. id just wanna know if this is ok, cause i dont wanna go thru the install again. but im really anticipating for the car to be done, ill have pictures up when im done.
the frame is intact, its just recomved from a fron end collision. the car looks fine now, just that when you look at the motor while its in the engine bay. the motor looks kinda tilted to one side, and when you look at the mounts, its kinda smushed and looks forced into the mount.
