How to do i get more torque?
Old Jul 29, 2003 | 11:03 PM
FLyPimp's Avatar
Default How to do i get more torque?
recently i had a 98 gsr motor swapped in my 93 civic hatch. i am running a p28 ecu, but that's not the point. . i was wondering how can i achieve more torque using bolt-ons or whatever else needed w/o using turbo, superchargers, and nos...thanks!
p.s. i have the basics intake, headers, and custom exhaust. once again thanks!
Old Jul 29, 2003 | 11:09 PM
azian21485's Avatar
Default Re: How to do i get more torque? (FLyPimp)
there's a thread on this...juss search
btw...torque requires displacement
Old Jul 29, 2003 | 11:12 PM
DJ KrunchyKracker's Avatar
Default Re: How to do i get more torque? (azian21485)
maybe ytour custom exhaust is too big. make the piping diameter smaller and u will increase backpressure and increase torque.
Old Jul 29, 2003 | 11:19 PM
mmuller's Avatar
Mad Scientist
Default Re: How to do i get more torque? (DJ KrunchyKracker)
you want torque? how much money you got?
Old Jul 30, 2003 | 02:02 AM
GTlvr82's Avatar
Default Re: How to do i get more torque? (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">you want torque? how much money you got?</TD></TR></TABLE>
Hondas don't have torque silly...unless you have mad money.
Old Jul 30, 2003 | 04:36 AM
NCSTIdriver's Avatar
Default Re: How to do i get more torque? (GTlvr82)
Skunk 2 stage 1's or 2's, Hondata, Portflow heads and dyno time. That should increase your torque a little
Old Jul 30, 2003 | 06:41 AM
Lsos's Avatar
FI will give you torque. A supercharger is good for low-end torque. You don't need displacement.
Old Jul 30, 2003 | 06:52 AM
xJ.SLOTHx's Avatar
Default Re: How to do i get more torque? (Lsos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lsos &raquo;</TD></TR><TR><TD CLASS="quote">FI will give you torque. A supercharger is good for low-end torque. You don't need displacement.</TD></TR></TABLE>
actually, if you want to remain n/a only way to gain a good amount of torque is to build your head and add some compression. you should be able to attain around 140lbs or so. But if thats not enough, you'll definitley need to increase displacement via big bore or stroke or both. or if you want a somewhat simple alternative, just boost on your motor. that should do the trick.
Old Jul 30, 2003 | 09:47 AM
Lsos's Avatar
Default Re: How to do i get more torque? (ian)
I thought he said w/ forced induction . Disregard my post.
Old Jul 30, 2003 | 10:12 AM
quikB18B's Avatar
Honda's werent mad ewith torque in mind your goal of torque with na are going to be hard wihtout FI, my suggestion is start with the head
Old Jul 30, 2003 | 11:01 AM
migs's Avatar
Default Re: How to do i get more torque? (quikB18B)
JDM ITR tranny
dohcgarage@714
Honda S2000
33
Nov 18, 2007 04:09 PM
Chemi421
53
May 11, 2006 07:21 AM
flip1199
Jun 18, 2005 01:37 PM
sloweredcivic
33
Jan 5, 2004 01:24 PM
