89 STD hb won't start need help troubleshooting
Old Jul 29, 2003 | 05:52 PM
reese's Avatar
Default 89 STD hb won't start need help troubleshooting
89 STD HB everything is stock
so far ive checked:
no ecu codes
dist. timing is good
dist., wires, and plugs good
fuses in engine bay good
car has been sitting for a few months and supposedly did crank a while ago but it did not crank after trying to jump start and letting it charge a few minutes but does not crank at all now. I think it could be fuel related but im not sure where I should check to narrow it down'
Old Jul 29, 2003 | 05:54 PM
Jared's Avatar
Default Re: 89 STD hb won't start need help troubleshooting (reese)
Does it crank and not start or just doesnt crank over at all.
Old Jul 29, 2003 | 05:55 PM
onePOINTsix's Avatar
so it turns over and wont start? then ya it's more then likly your fuel system. Try replacing your fuel filter, if that dosent work then add some of that Anti Water fuel additive and let it sit a while because water coiuld have got into the system
reese's Avatar
Default Re: 89 STD hb won't start need help troubleshooting (Jared)
it used to crank from what the owner says but now it does not crank at all after trying to jump start and letting the battery charge a few minutes
Old Jul 29, 2003 | 11:36 PM
reese's Avatar
fuel relay? fuel filter? just need a list to check off first to last
Old Jul 30, 2003 | 02:17 PM
mr. carpenter's Avatar
main relay. located under the dash, drivers side, behind the coin holder
prodjay10
Jan 17, 2017 09:12 AM
Ace0246
13
Sep 3, 2005 12:09 AM
drifto808
Dec 3, 2003 04:15 PM
incognitoracerr
Oct 6, 2003 12:03 PM
