b18b swap help - timing off??????
Old Jul 29, 2003 | 03:54 PM
89Si's Avatar
Default b18b swap help - timing off??????
I finally got everything all hooked up. I went to start it today in the garage(still on jack stands-no axles yet), and it barely turns over. The timing sounds really bad to me. I checked the plug wires and the spark, and they are both fine. It was my first timing belt install, and that is really starting to concern me. I followed helms all the way through it, and double checked it when I was through. I'm still not positive I did it right though. The only other thing I can think of is my 90-91 dizzy off ebay. If it was a 92-93, would that make a big difference? HELP! I don't feel like taking it all back out again. Any other ideas???? thanks.
Old Jul 29, 2003 | 04:29 PM
89Si's Avatar
Default Re: b18b swap help - timing off?????? (89Si)
I just checked the cam gears, and they are still lined up correctly. Is it safe to take off the crank pulley while the motor is in the car? And should I even bother trying to tell if its timed correctly that way? Would I be able to see the oil pump mark that way? thanks.
Old Jul 29, 2003 | 05:00 PM
91civicEX's Avatar
the crank pulley should have a mark on it. also how strong is your battery that could effect how fast it cranks. did it start?
Old Jul 30, 2003 | 03:36 AM
89Si's Avatar
Default Re: (91civicLX)
it starts sometimes, but only stays on for a second or two at the most.
KenJoTuning
10
May 30, 2012 01:15 PM
alex14
12
Sep 29, 2010 01:01 AM
Stiff_Crx
14
May 27, 2009 08:25 PM
hondakevin21
Jan 21, 2009 07:42 PM
Danronian
Apr 12, 2006 03:06 PM
