HELP! Check light!
I was driving and my check light went on. Can a bad ignition coil cause it to light up? I know for a fact that my coil is bad cuz my tach jumps.
So I resetted my ECU and got rid of the check light. If the check light doesn't go on in the future, do I still need to worry about it?
You should have pulled the code to be certain.
https://honda-tech.com/zerothread?id=403633
Pata outlines it fairly well, I like to bend up a small paperclip to jumper the connector.
Next time it happens, get the code and find out what it's whining about. Then go from there.
As for the coil possibly causing a CEL, it's likely it could. But you'll never know now
G. Man
12
Feb 25, 2011 06:13 PM
