Coolant temp sensor issues????????
Old Jul 29, 2003 | 01:14 PM
7PSiEF9ZC's Avatar
Default Coolant temp sensor issues????????
After blowing up my turbo ZC I've now switched to B series. I have a OBD 1 Cable trans B16a. But I switched the dizzy , injectors , and ECU so I'm running it as a OBD 0 motor. Now my question is on my old ZC harness and basicly is the same as any 88'-91' Civic/CR-X Si if I remember the motors and harnesses use only one connection for the coolant temp and two kick on the fans where as on my B16 there's the coolant temp sensor under the VTec soliniod and the fan switch sensor on the thermostat housing right ? Now when I goto to put the B16 do I just connect the connector on my harness to the sensor on the head under the VTec soliniod and leave the one on the thermo housing alone or what do I have to do. Also my friend was saying that I may have to switch out the sensor on the head for a OBD0 sensor is this true I thought they were the same. Basicly I just want to know what I have to do as far as the coolant temp sensor goes ? Thanks
Old Jul 29, 2003 | 02:06 PM
7PSiEF9ZC's Avatar
Default Re: Coolant temp sensor issues???????? (7PSiEF9ZC)
Also does it matter if I only have to use one sensor which one it is. ( i.e. housing or head )
duneracer69
Jun 14, 2008 03:15 PM
busyychild
May 6, 2008 11:09 AM
kramer06
Jan 24, 2008 05:41 PM
K.Quinn
Apr 29, 2007 06:07 PM
scratchline20
Jul 29, 2003 01:40 PM
