cam plug install
Old Jul 29, 2003 | 01:12 PM
boi-alien's Avatar
Default cam plug install
never done this before, but i was wondering what's the steps to take in order to replace a cam plug on a b16a motor. i have the cam plug, i was told there's a certain sequence to remove the bolts to get access to it. and i need to tq it a certain spec. i was wondering if anyone could give me a hand with this? thanks any info would be appreciated
Old Jul 29, 2003 | 04:32 PM
MightyMouseTech's Avatar
Default Re: cam plug install (boi-alien)
An easier way to do it is to get the P72 plug (I think it's a P72, I'm not at work so I am just working from memory. This plug is plastic with an O-ring on it) If you use this plug you don't have to unbolt anything. Just pull out the old one with a screwdriver being carfull not to score the alluminum (punch hole in middle and pry) and then pop in the new one. Takes about 5 minutes and no disassembly required. Plus, I have never seen an o-ring cam seal leak. Unlike the all rubber over metal core ones which always leak after a while.
Old Jul 31, 2003 | 05:41 PM
Default Re: cam plug install (MightyMouseTech)
I just double checked, the full part number is 12513-P72-003 for the cam plug.
Hope this helps.
Old Aug 13, 2003 | 09:42 AM
boi-alien's Avatar
thanks a lot man
Old Aug 13, 2003 | 11:01 AM
rsbad454's Avatar
i havent had any problems with the aluminum plugs.............
mickey513
Jan 30, 2015 09:32 AM
phateless
Mar 30, 2010 05:28 PM
ThatGreenGsr
Sep 14, 2008 07:45 AM
pancake
Feb 10, 2005 01:50 PM
