Where to buy and adjustable upper ball joint?
Old Jul 28, 2003 | 08:39 PM
Blaze45's Avatar
Brrraaaap!
Default Where to buy and adjustable upper ball joint?
I need em cause I dont want to get a camber kit and the guy at Les Schwab said that this would be the way to go since I wasnt going to lower the car. If you know where you can get one for cheaper then 100 bucks a pop lemme know...
Blaze
Old Jul 29, 2003 | 07:14 PM
Esoterikos's Avatar
just curious, but if you aren't lowering the car, and you don't want a camber kit, why would you want adjustable upper ball joints?
most camber kits for civics are adjustable ball joints.
Old Jul 30, 2003 | 01:51 PM
Blaze45's Avatar
Brrraaaap!
Default Re: (S8P-tuner)
to me. I've never seen a camber kit myself in person..... My B20 weighs so much that its throwing the camber off like 1 deg. in my rex.
Blaze
Old Jul 30, 2003 | 04:40 PM
MightyMouseTech's Avatar
Default Re: (Blaze45)
You need a camber kit. It is just that you lowered your car not by putting in lowering springs, but by adding weight to the nose.
Old Jul 31, 2003 | 04:11 PM
Esoterikos's Avatar
Default Re: (MightyMouseTech)
that makes a lot more sense, now. you may also want to consider putting in new springs...maybe not necessarily lowering springs, but at least ones with higher spring rates, since your front end is so much heavier. and one degree of camber is not bad, it is still within factory specs of most hondas. i've got 2 degrees negative camber in my civic, and it doesn't bother me. i've considered fixing it, but it holds better in the corners. you should be okay with one degree...
Old Jul 31, 2003 | 04:19 PM
Blaze45's Avatar
Brrraaaap!
Yeah, maybe you can help me with my other problem. I broke my sisters IM. I broke a chunk off right by the coolant passage by the #4 runner.... Can I just JB weld it? Will that hold?
Blaze
v8 killer
Honda Civic (2006 - 2015)
Mar 9, 2012 04:02 PM
drkstrs24
14
Mar 29, 2011 07:45 PM
chatman_55
Apr 5, 2009 01:34 PM
93 VTEC
Oct 19, 2002 03:03 PM
