how can i check if i have a lsd tranny? b16a II
Old Jul 28, 2003 | 08:31 PM
tek_civic's Avatar
Default how can i check if i have a lsd tranny? b16a II
how can i check if my b16 tranny is lsd equipped? i can launch pretty hard with little tire burning and whn i do a burnout it always leaves 2 equal marks. is there something i can look for like some box or a code or anything to know for sure?
Old Jul 28, 2003 | 08:38 PM
whitehatch11's Avatar
do a search for it but i believe if your car is on jack stands, you can spin one wheel and the oposite wheel should turn the oposite way, anybody say something if i messed that up..
Old Jul 28, 2003 | 08:48 PM
Shawn C's Avatar
In The Garage
heres how you tell- pull out the axles, and look through the diff. if there's a little bar crossing inside the opening, it's not an LSD. if it's straight-through, it's an LSD.
Old Jul 28, 2003 | 09:05 PM
tek_civic's Avatar
Default Re: (22lbGS-R)
is that the only way or can i just jack it up and spin the wheels? there should be some code on it or something right?
Old Jul 29, 2003 | 10:43 AM
tek_civic's Avatar
Default Re: (tek_civic)
ya i need to replace my right axle anyways so i might as well check while im at it. quick question, when i do a burnout or launch really hard i leave 2 equal tires marks, where if i had a non lsd tranny it should leave one mark or one heavy and one light mark right?
Old Jul 29, 2003 | 10:59 AM
WAFFLES's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 22lbGS-R &raquo;</TD></TR><TR><TD CLASS="quote"> heres how you tell- pull out the axles, and look through the diff. if there's a little bar crossing inside the opening, it's not an LSD. if it's straight-through, it's an LSD.</TD></TR></TABLE>
That's the best way...
Old Jul 29, 2003 | 11:04 AM
Filliam H. Muffman's Avatar
Default Re: (WAFFLES)
agreed
ctr32
Transmission & Drivetrain
Jun 12, 2009 11:27 AM
darockstar
Dec 7, 2006 07:39 PM
drSquish
Oct 13, 2005 08:03 AM
ludewithanh22
Aug 23, 2004 09:30 AM
sambam27
Sep 7, 2003 04:28 PM
