Ati harmonic balancer ?'s
Old Jul 28, 2003 | 08:12 PM
Tbone's Avatar
Default Ati harmonic balancer ?'s
Are any of you guys running them? If you are did you have to hone it to get it to fit the crank and what style hone did you use? All the hones that the local machine shops have with the stones will break because of the woodruf key groove. Any info would be appreciated.
Old Jul 29, 2003 | 10:07 PM
Tbone's Avatar
Default Re: Ati harmonic balancer ?'s (Tbone)
Dont make me sand paper this thing guys..lol(jk)
Old Jul 29, 2003 | 11:58 PM
SlicksMH's Avatar
Hay guy's this racer's need help, can somebody step up to the plate. John@M&H
Old Jul 30, 2003 | 04:01 AM
compact-tuner's Avatar
well i know that we run the ati on our pro 4 car.the engine is a b18c1 and we had no problems getting the balancer on.we used a little anti sieze and the ati pulled right on with little effort with the crank bolt.make sure to locktite all of the bolts,it will come back to bite ya if ya did not!
good luck
brian jenkins
sangamonvalleyracing.com
pro4 cyl #8434
Old Jul 30, 2003 | 06:43 AM
MAX_CFM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tbone &raquo;</TD></TR><TR><TD CLASS="quote">Are any of you guys running them? If you are did you have to hone it to get it to fit the crank and what style hone did you use? All the hones that the local machine shops have with the stones will break because of the woodruf key groove. Any info would be appreciated.</TD></TR></TABLE>
I have honed about 200 Ati balancers
Use a rod hone, just take it appart dont rip the o-rings
remeber this is a press fit .
Some people like too heat them up
and then beat it on.
Old Jul 30, 2003 | 09:43 AM
Tbone's Avatar
Default Re: Ati harmonic balancer ?'s (MAX_CFM)
Thanks for the info guy's . I'm told theres a intstaller/puller I can buy to make the job easier, my only worry is that once its in my crx theres no room to even get to the pully unless I drop the motor down. I still need to check to see if it will clear my z10 traction bars. So I dont want to hone it just yet. I might have to go to a industial machine shop to find a bar hone too, as my local guy doesnt have one.
JDM00SI
Nov 15, 2005 10:16 PM
92vteclude
Sep 1, 2005 12:41 PM
johnzm
Jan 24, 2005 05:28 PM
Slow96RedEk
Dec 21, 2003 06:35 PM
BlueSi2k
May 8, 2003 11:08 AM
