what do i need to make a custom turbo kit
Old Jul 28, 2003 | 07:50 PM
deeweezy's Avatar
Default what do i need to make a custom turbo kit
like the topic says what all do i need to make my own custom turbo kit
Old Jul 28, 2003 | 08:04 PM
nigel's Avatar
prepare to get flamed. go to homemadeturbo, read every turbo project there is, and you will know what you need.
Old Jul 28, 2003 | 08:09 PM
deeweezy's Avatar
ooooooook watever u say
Old Jul 28, 2003 | 08:43 PM
deeweezy's Avatar
damn nobody
Old Jul 28, 2003 | 08:45 PM
Accord94DX's Avatar
Default Re: (deeweezy)
Buy a kit. Its just easier. If you have to ask this question I'm not sure you would be so happy in the end with your kuSt0m kit
Old Jul 28, 2003 | 09:18 PM
vtec.dc2's Avatar
Default Re: what do i need to make a custom turbo kit (deeweezy)
first, what kind of car/motor and what to use it for.. and how much whp do you want to make and do you plan to make? you're asking a general question, be more specific.. or maybe post what you know..
most of the main parts will include
- exhaust manifold
- turbocharger (oil cooled or water + oil cooled)
- intercooler with intercooler/charge piping
- bov flange and bov
- oil send/return line (you'd want both in stainless steel)
- vacuum hose lines, splitters
- spark plugs
- exhaust large enough to support whatever hp.
a turbocharger may include internal wastegate, but in general you'll get better power results with external wastegate that will go on top of manifld
fabrication may include downpipe if not from some turbo kit, intercooler/charge piping, possibly an an extension elbow for external wastegate, dumptube for wastegate, modifications around radiator if you want front mount intercooler, tapping oil pan oil line. sometimes its easier to just buy piping from the kit.. - fabrication might be needed but not as much.
basic gauges should include boost and oil pressure..
if you want your setup to work better choose standalone for fuel management instead of fmu.. if you choose a standalone.. you will need standalone ecu, larger injectors, intank fuel pump, f.p.r..
other accesories may include oil cooler/oil catch can/more gauges/boost controller/turbo timer.
in general the more hp you run, the more stock parts you may need to upgrade.
(choosing turbo trim: you can go with what others use on similar setup. or research for yourself by learing compressoin maps and matching it to your car.. formulas are out there)
Old Jul 28, 2003 | 09:31 PM
chri5's Avatar
Default Re: what do i need to make a custom turbo kit (vtec.dc2)
If you really do not know what you need, then you should try and piece one together IMO.
Old Jul 28, 2003 | 10:37 PM
mos's Avatar
mos
Default Re: what do i need to make a custom turbo kit (Strng1dah)
Kits were made for people like you!
Old Jul 28, 2003 | 10:50 PM
ScottEK's Avatar
Default Re: what do i need to make a custom turbo kit (mos)
Time, money, and know somebody who can weld good.
MrArney
Aug 16, 2013 05:41 PM
yaaj1320
Southeast (Sales)
24
Jul 25, 2007 07:04 AM
OG SHG_EM1
Mar 28, 2004 09:10 PM
OEMJDM
Jan 21, 2003 03:37 PM
