jdm headlight install
Old Jul 28, 2003 | 07:21 PM
Luder85's Avatar
Default jdm headlight install
do you know where i can find out how to install the wiring harness...step by step...if you do let me know where/how
Old Jul 28, 2003 | 07:24 PM
PetroGuyX's Avatar
http://www.hondaprelude.to/install_jdmlights.html
Old Jul 28, 2003 | 07:46 PM
optikal_blitz's Avatar
Default Re: (PetroGuyX)
yep. or:
http://www27.brinkster.com/sons/jdmlights.html
Old Jul 28, 2003 | 09:45 PM
Que_Lude's Avatar
Default Re: jdm headlight install (Luder85)
Some of those sites have you connect a relay to get the High beams to work on the H4's. You just need to connect the lights the same way as the USDM's. Low's to low, High's to high. Solder and heat shrink the connections.
Old Jul 29, 2003 | 03:19 AM
Default Re: jdm headlight install (Que_Lude)
i think the reason for the relays is the fact that the inner lights that would be the high beams on the usdm ludes are the 'fog' lights on the jdms that need to shut off while the highs are on. so you would use a relay for this. i could be mistaken though.
Old Jul 29, 2003 | 05:46 AM
Prelude Vtec 23's Avatar
Default Re: jdm headlight install (NatakuBlitz)
I have a question....does these light have the turn signals built into the coner lights on the jdm lights?
Old Jul 29, 2003 | 06:12 AM
PetroGuyX's Avatar
no sir, i do believe those are still the parking lights
Old Aug 4, 2003 | 08:53 AM
Lip's Avatar
Lip
thats correct. still parking lights
hatch96y7
22
Oct 17, 2006 03:02 PM
NorthernXposure
Aug 11, 2006 02:11 AM
SiSpopu
Acura TL, RL & ZDX
Jul 22, 2006 02:46 PM
lenn
Mar 23, 2003 12:08 AM
SKRacer
Dec 25, 2001 02:14 PM
