Getting RX-7 Wheels
Old Aug 6, 2001 | 07:02 AM
Wicked_R's Avatar
New User
Default Getting RX-7 Wheels
Hey Guys,
I am getting a set of RX-7 wheels for the R so that I can use them for the track. I was wondering what tire would fit well and not rub. FYI the 3rd gen RX-7 are 16 inch. All help is appreciated!
Old Aug 6, 2001 | 07:08 AM
B18CXr's Avatar
Default Re: Getting RX-7 Wheels (Wicked_R)
225's will fit but you need to space the rear's out a touch....
Old Aug 6, 2001 | 07:36 AM
Black R's Avatar
25 Year Member
Welcome to the club.
You, me and 2fcknfst are the only ones with fd wheels thus far...
At less than 13 lbs, these are nice 16x8 wheels!
Oh yeah, don't forget to run a 3mm spacer.
[Modified by Black R, 11:37 AM 8/6/2001]
Old Aug 7, 2001 | 05:49 AM
Wicked_R's Avatar
New User
Default Re: Getting RX-7 Wheels (Black R)
how much is a spacer and do need them only for the rears?
Old Aug 7, 2001 | 05:51 AM
Wicked_R's Avatar
New User
Default Re: Getting RX-7 Wheels (B18CXr)
do I use 225 all the way around or just in the front?
Old Aug 7, 2001 | 06:10 AM
Black R's Avatar
25 Year Member
Old post with some info:
https://honda-tech.com/zeromodify?cm...post&id=388703
Oh yeah, and 215/45/r16 seem to be the size to use for stock rolling diameter and not to rub... 225's will apparently rub a little...
[Modified by Black R, 10:15 AM 8/7/2001]
Old Aug 7, 2001 | 11:29 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
hey black R, i had a set of rx7 wheels too........
Old Aug 7, 2001 | 11:33 AM
R1020's Avatar
hey BlackR, what's the offset on those FD wheels?
Old Aug 7, 2001 | 11:54 AM
Black R's Avatar
25 Year Member
Default Re: Getting RX-7 Wheels (rodney)
heh, long time "rod-knee!" How are you? Did you ever get vtec working on your hybrid? I've got b's too now... I just need a test pipe/ high flow cat and exhaust... And I need to tune!
1020, I have no idea of the offset... I think 3mm spacer brings them to 47mm offset, so that means they are.....44mm offset?
Old Aug 7, 2001 | 12:00 PM
Wicked_R's Avatar
New User
are the spacers necessary to have? I have heard that using spacers are not safe, is this true?
Old Aug 7, 2001 | 12:02 PM
Black R's Avatar
25 Year Member
should be fine.
2fcknfst has been running these for a while now with no problems. And I doubt he babies his car....
Also, many others like yoshi run spacers at auto-x to run wider rubber - no problems for yoshi either... Although he did bang up a rim on the streets of LA... But that's just potholes.
Old Aug 7, 2001 | 12:12 PM
R1020's Avatar
if a 3mm spacer brings them to 47mm, then they are 50mm. that's cool . . . where can i find a set?!
Old Aug 7, 2001 | 12:19 PM
Wicked_R's Avatar
New User
Default Re: Getting RX-7 Wheels (R1020)
look for them at an RX-7 message board
Old Aug 7, 2001 | 12:37 PM
R1020's Avatar
know of a good one? rx-7.com?
Old Aug 7, 2001 | 12:42 PM
typer_801's Avatar
No. If a 3mm spacer brings them to 47mm, then they are 44mm as stated earlier.
Old Aug 7, 2001 | 01:59 PM
2fcknfst's Avatar
Waddya mean I don't baby my car?
Obviously you haven't seen it...
About the wheels, they are 50mm offset. A 3mm spacer will bring the offset OUT to 47mm.
Hope it helps...
Old Aug 7, 2001 | 02:06 PM
Type R's Avatar
Does anyone have any pictures of the rx7 wheels?
thanx
Old Aug 10, 2001 | 08:03 AM
Black R's Avatar
25 Year Member
Default Re: Getting RX-7 Wheels (2fcknfst)
Oops! I haven't seen your car in person. It looked clean in the pics, but we all know you drive the snot out of it!
Oops again! Well, I guess we all finally know! They are the same offset as the millenia wheels and the usdm itr wheels. But we need to run a 3mm spacer to clear the rear suspension...
Now I wonder if I could just use a 5mm spacer without any problems... (Less hassle to get it machined, etc...)
Old Aug 10, 2001 | 08:05 AM
J Ritt's Avatar
Where are the pics?
Suzukablue
Nov 22, 2012 08:33 AM
hunterln
Nov 30, 2009 01:19 PM
done
May 5, 2009 09:45 AM
00siBuilder
Mar 29, 2004 03:41 AM
YodaIsGod
14
Apr 8, 2003 03:18 PM
