Cause of a blown HG? Also, tips. hints on removal,install D15Y7
Old Jul 28, 2003 | 04:37 PM
Blaze45's Avatar
Brrraaaap!
Default Cause of a blown HG? Also, tips. hints on removal,install D15B7
I've got to replace it on my sisters 93 Civic. Anything on the removel, install that would be worth warning about, please post it up.
tia
Blaze
Modified by Blaze45 at 5:41 AM 7/29/2003
Old Jul 28, 2003 | 06:00 PM
tinkerbell's Avatar
Default Re: Cause of a blown HG? Also, tips. hints on removal,install D15Y7 (Blaze45)
nothing you dont see in a B series...
make sure you flush out the coolant, ie take out thremostat, and front plug and flush all the crud out...
and have the radiator checked too...
t..
Old Jul 28, 2003 | 06:07 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Cause of a blown HG? Also, tips. hints on removal,install D15Y7 (tinkerbell)
What about milling the head? Her car has never seen the H spot on the temp gauge, but she has heated it up. Would this be a nesscity?
Blaze
Old Jul 28, 2003 | 06:10 PM
tinkerbell's Avatar
use your helms to check the head for warpage...
do you know why it has blown? what are the symptoms?
you will generally find out more one you lift the head off and inspect the gasket for the point of rupture... this will tell you more...
Old Jul 28, 2003 | 08:37 PM
Blaze45's Avatar
Brrraaaap!
Well it mostly becuause its eating coolant like crazy. My sister also had it tested, they put a chemical into the coolant that turns red if the exh. is getting into the coolant. Its not blowing any smoke though. What would caues this to happen? We have an 87 Accord that has 250k on it, we have never had to put a HG on it.
thanks
Blaze
Old Jul 29, 2003 | 07:30 AM
Blaze45's Avatar
Brrraaaap!
Anyone on why this takes place??
Blaze
1989civichatch
18
Sep 15, 2011 10:09 PM
GotToyota
Honda Civic (2001 - 2005)
Nov 24, 2008 10:18 PM
A Tribe Called Honda
Feb 21, 2008 03:19 PM
hb_guy
Oct 29, 2005 06:12 PM
veejay
Jun 30, 2001 09:02 AM
