I think I just broke my axles..... Help!
Old Jul 28, 2003 | 12:23 PM
Blaze45's Avatar
Brrraaaap!
Default I think I just broke my axles..... Help!
Yeah, so I go to let the clutch out at about 5k and I hear this loud clunk.... I put it into gear and the speed hurries up to 30mph... But the car doesnt move..... So I think that they are broke... my question is, can the int. shaft break? Also, when I let the clutch out the wheel would mmm well its hard to explain but, it would shake, I look'd under the car and the axle would shake.(I noticed this b4 the axles broke...) Would bad joints in the axles cause this to happen?
Thanks...
Modified by Blaze45 at 2:24 AM 7/29/2003
Old Jul 28, 2003 | 12:43 PM
snowcrash's Avatar
Default Re: I think I just broke my axles..... Help! (Blaze45)
When I had a defective clutch my car would shake like hell when I took off. Looking at the wheel it looked like it was almost bouncing. Maybe you're clutch went out?
Old Jul 28, 2003 | 12:54 PM
Blaze45's Avatar
Brrraaaap!
Default Re: I think I just broke my axles..... Help! (snowcrash)
I dont think that the clutch went out cause I still put it in gear and the speedo is still moving...
Blaze
Old Jul 28, 2003 | 02:09 PM
raene's Avatar
You put it in gear, the speedo is moving, and the car isn't?
Old Jul 28, 2003 | 02:26 PM
bagged89hatch's Avatar
Default Re: I think I just broke my axles..... Help! (raene)
only way to tell is jack it up and look
Old Jul 28, 2003 | 03:02 PM
Jared's Avatar
Default Re: I think I just broke my axles..... Help! (bagged89hatch)
If the speedo moves and the car doesn't you have one of two things broken, the differential spider gears or an axle. Jack the car up, put it in gear and run it. One of the two axles will move if you have a broken axle, just trace the moving axle until you get to the joint that you don't see movement anymore and you've found your broken point. What were you doing when this happened?
Old Jul 28, 2003 | 04:22 PM
Blaze45's Avatar
Brrraaaap!
Default Re: I think I just broke my axles..... Help! (Jared)
I dropped the clutch at about 5k to peel out and well, clunk.... I hope I didnt take out the spider gears... The speedo still moves and I can put it into any gear, no problem... It will hardly move forwards or backwards... How can I tell which side is broken? Also I can see the axles just spinning... Would they be able to spin if the spider gears were broke? OT but does any one know where to buy adjustable upper ball joints?
Blaze
Old Jul 28, 2003 | 05:11 PM
xci_ed6's Avatar
so both spin, but the outer CV does not?
-Dustin
Old Jul 28, 2003 | 05:14 PM
Blaze45's Avatar
Brrraaaap!
Default Re: I think I just broke my axles..... Help! (krustindumm)
well im gonna jack it up shortly and see...
Blaze
Old Jul 28, 2003 | 06:13 PM
Blaze45's Avatar
Brrraaaap!
Well poop. The drivers side axle is no more. My dad recomeded that I should get an upgraded axle(s) to handle the trq from the B20. Should I spend the $$ for one that can handle the power?
Blaze
Old Jul 28, 2003 | 06:17 PM
civichopeful's Avatar
I actually had that happen to me. Put the car in gear, let out the cutch and pop, snapped the axel right at the hub. The guy I brought it to had never seen that happen. And that was with the stock D15's massive 74 hp.
Old Jul 28, 2003 | 06:22 PM
Blaze45's Avatar
Brrraaaap!
Default Re: I think I just broke my axles..... Help! (civichopeful)
LOL... Yeah well I still cant decide if I should upgrade axles....
Blaze
Old Jul 28, 2003 | 06:41 PM
Timmah!!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 &raquo;</TD></TR><TR><TD CLASS="quote">LOL... Yeah well I still cant decide if I should upgrade axles....
Blaze</TD></TR></TABLE>
Get 2 pair from autozone. When you snap another, replace it with one that you carry in your car. A day later bring the broken one back to autozone, and get it replace for free. Lifetime guarantees rock ***!.
Old Jul 28, 2003 | 07:30 PM
Jared's Avatar
Default Re: I think I just broke my axles..... Help! (azroth)
Advance carries GCK remans that are pretty good, at least as good as the OE stuff. it's not crap like the rest of the remans.
Old Jul 28, 2003 | 08:26 PM
Blaze45's Avatar
Brrraaaap!
Hmm, I look into that. The autozones dont sound bad...
Blaze
CarBug
Jun 9, 2016 02:58 PM
OhBai
Jan 21, 2012 06:58 PM
jeff79
11
Nov 26, 2008 03:17 PM
veilsides2000
Jan 15, 2006 08:51 PM
FULL-REV
Jun 30, 2005 04:24 AM
