high flow cat o2 sensor
Old Jul 28, 2003 | 12:17 PM
f1uxx's Avatar
Default high flow cat o2 sensor
i just got a high flow cat and it was displayed with a o2 sensor in it and i got it without one , will the car run without it ? i have a 00 integra LS thanks
Old Jul 28, 2003 | 12:50 PM
dohc-nyne's Avatar
get it fitted onto ur high flow cat at ur local muffler shop...unless u want to go obd1 with a jumper harness...
Old Jul 28, 2003 | 02:04 PM
MooreBoost's Avatar
Default Re: (dohc-nyne)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohc-nyne &raquo;</TD></TR><TR><TD CLASS="quote">get it fitted onto ur high flow cat at ur local muffler shop...unless u want to go obd1 with a jumper harness...</TD></TR></TABLE>
You could get a new one welded in, but ther is no need for obd1 in this situation. You can just get an o2 fooler wired it 75 bucks installed.
gmoore
Old Jul 28, 2003 | 03:15 PM
dohc-nyne's Avatar
Default Re: (tegunderpressure)
i forgot about the o2 simulator
Old Jul 28, 2003 | 06:40 PM
f1uxx's Avatar
where exactley do i get the simulator installed?
Old Jul 28, 2003 | 06:55 PM
MooreBoost's Avatar
Default Re: (f1uxx)
Any high performance shop should be able to do it. If they have it, they should install it. Just call around for o2 foolers.
gmoore
Old Jul 28, 2003 | 07:46 PM
f1uxx's Avatar
thanks for the help
6thgenva
Welding / Fabrication
Oct 14, 2010 07:11 AM
gulftiresinc
Sep 23, 2004 04:51 AM
otakueric
May 23, 2004 11:52 AM
hotboi850
Aug 18, 2003 08:46 PM
GMan_CRX
Jun 18, 2003 12:35 PM
