B&M command flo.. leaking....
got a B M FPR... it shoots out fuel when i put it in... dunno what i did wrong... also is my fuel pressure suppose to drop to zero after i shut off my car for a while??
Woah, I wouldn't do anything untill you get that fixed. Your problem is probably caused by you not sawing enough of the regulator off. I'd take it apart (make sure you have the rubber seal in place) saw/file it down (not too much), and reinstall it. I've never had any problems and I've installed about 6 of them. HTH, -C
i got an extra stock fpr... well.. imma do it again but... someone told me that u were suppose to cut it by the top of the hat and said i cut too much... how much are u suppose to cut??
yeah, it comes with all the instructions.
To the origonal poster, just try and fix the first one. It probably just isn't sitting flush. You should cut the hat about halfway or so. HTH, -C
vtec25
May 4, 2006 07:53 PM
full Circling
Aug 5, 2005 08:30 PM
