B&M command flo.. leaking....
Old Aug 6, 2001 | 02:19 AM
wdyno's Avatar
New User
Default B&M command flo.. leaking....
got a B M FPR... it shoots out fuel when i put it in... dunno what i did wrong... also is my fuel pressure suppose to drop to zero after i shut off my car for a while??
Old Aug 6, 2001 | 08:57 AM
TypeC's Avatar
Default Re: B&M command flo.. leaking.... (wdyno)
Woah, I wouldn't do anything untill you get that fixed. Your problem is probably caused by you not sawing enough of the regulator off. I'd take it apart (make sure you have the rubber seal in place) saw/file it down (not too much), and reinstall it. I've never had any problems and I've installed about 6 of them. HTH, -C
Old Aug 6, 2001 | 03:48 PM
wdyno's Avatar
New User
i got an extra stock fpr... well.. imma do it again but... someone told me that u were suppose to cut it by the top of the hat and said i cut too much... how much are u suppose to cut??
Old Aug 6, 2001 | 03:57 PM
B18C-EJ1
Guest
Posts: n/a
Cut about 1/4" off the top. Then make sure you install the rubber seal as stated above.
It shouldn't leak at all.
Old Aug 6, 2001 | 04:59 PM
Chris's Avatar
So the command Flo is the Riser. I am interested in this, does it come with thesr mod instructions, or is that to fit our cars??
Thanks
Old Aug 6, 2001 | 07:08 PM
TypeC's Avatar
Default Re: B&M command flo.. leaking.... (Chris)
yeah, it comes with all the instructions.
To the origonal poster, just try and fix the first one. It probably just isn't sitting flush. You should cut the hat about halfway or so. HTH, -C
vtec25
May 4, 2006 07:53 PM
213374U
Aug 22, 2005 09:10 AM
full Circling
Aug 5, 2005 08:30 PM
dLo GSR-stolen-now-WRX
Jun 8, 2002 11:12 AM
Halo
Jun 15, 2001 11:36 AM
