Headlight Bulb Replacement for EG
Old Jul 28, 2003 | 10:56 AM
Caveman74's Avatar
Default Headlight Bulb Replacement for EG
Do you have to take the whole assembly out to get the bulb out. I noticed it had two phillips screws holding the bulb in and I cant reach the screws. Thanks
Old Jul 28, 2003 | 11:14 AM
illusive's Avatar
Default Re: Headlight Bulb Replacement for EG (Caveman74)
Take the rubber piece off from the headlight housing then there will be a bent piece of wire push that in and pull up. Its kind hinged so it will move no need to take the screws out.
Old Jul 28, 2003 | 11:28 AM
kay_animation's Avatar
Default Re: Headlight Bulb Replacement for EG (illusive)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by illusive &raquo;</TD></TR><TR><TD CLASS="quote">Take the rubber piece off from the headlight housing then there will be a bent piece of wire push that in and pull up. Its kind hinged so it will move no need to take the screws out.</TD></TR></TABLE>
Yup, that guys right, replace the bulb, don't touch the glass part of the bulb at all and be carefull not to get any of that grease stuff thats on the headlight harness on the bulb You should be good.
Old Jul 28, 2003 | 12:02 PM
Caveman74's Avatar
Thanks, I tryed last night an it just seemed to be a pain in the ***. I'll try that way
NOFX
17
Oct 11, 2008 04:25 PM
Pooby88
Jan 5, 2008 12:44 PM
thecrackerjack
Lighting
Sep 9, 2007 05:38 PM
ef_you_again
Apr 10, 2005 12:57 PM
Si Arn
May 4, 2004 05:37 PM
