Headlight Bulb Replacement for EG
Do you have to take the whole assembly out to get the bulb out. I noticed it had two phillips screws holding the bulb in and I cant reach the screws. Thanks
Re: Headlight Bulb Replacement for EG (Caveman74)
Take the rubber piece off from the headlight housing then there will be a bent piece of wire push that in and pull up. Its kind hinged so it will move no need to take the screws out.
Re: Headlight Bulb Replacement for EG (illusive)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by illusive »</TD></TR><TR><TD CLASS="quote">Take the rubber piece off from the headlight housing then there will be a bent piece of wire push that in and pull up. Its kind hinged so it will move no need to take the screws out.</TD></TR></TABLE>
Yup, that guys right, replace the bulb, don't touch the glass part of the bulb at all and be carefull not to get any of that grease stuff thats on the headlight harness on the bulb You should be good.
ef_you_again
04-10-2005 12:57 PM
Si Arn
05-04-2004 05:37 PM
