bfg drag radial launching?
Old Jul 28, 2003 | 09:32 AM
vodomagoo's Avatar
Default bfg drag radial launching?
how would you guys recomend launching with the drag radials, also what psi should be in them? i was doing burnouts after going through the water box till they started smoking and it seemed to be working but is that the right way?
Old Jul 28, 2003 | 09:41 AM
AussieK24's Avatar
Default Re: bfg drag radial launching? (vodomagoo)
What were your 60' times?
Old Jul 28, 2003 | 10:42 AM
PM-Performance's Avatar
its all abotut hat sweet spot.
i tried thme once at 14psi reccomended from BFG i launched at 5k on the 2step and it hooked pretty decent, but a little wheel hop , slight spin , i think it needed a hair higher launch
smoeone told me to launch lower becuase the traction issues, they told me 4k? i thought it was crazy so i tried 4500, and i knoew i shouldnt have went lower, but broke an axle on that launch becuase of severe wheeel hop .i say as long as you have a good clutch start higher and work down , 5k is usually a good spot to start from
Old Jul 28, 2003 | 01:16 PM
TwoRedEGgs's Avatar
Default Re: bfg drag radial launching? (itr206)
It depends on the motor setup and power you have really but, yo wanna make sure you get them nice and sticky. Then like i said it depends on your setup. Do some test runs at different rpm's to check. We launched a h22 civic coupe at 3k and it spun a little. I also recommend getting traction bars the help allot by getting grid of all the wheel hop. I know someone pulling 1.6 60's on slicks so that would be like a 1.8-1.9 on BGF's and thats pretty good. For every 1/10 of your 60 time you can expect like 1-2 1/10's of your et so work on it a bit!!
tapboyzlilj
Dec 24, 2007 02:20 PM
TravSi
Aug 11, 2003 01:50 AM
DX Hybridizer
Apr 22, 2003 04:00 PM
PM-Performance
Mar 25, 2003 09:52 AM
CM-R
Oct 14, 2002 10:02 AM
