ahhhHHH my EF driver side window broke!
Old Jul 28, 2003 | 08:11 AM
pinoyboy204's Avatar
Default ahhhHHH my EF driver side window broke!
heres the story...i have a 90 honda civic hb and one day my window just went kaput. so i opened the door panel to find that the lever or that cross bar that holds the window is bent. is there anyway to replace it or fix it. it seems like a really tight spot to try and fix it. any ideas or answers would be great.
Old Jul 28, 2003 | 04:45 PM
Default Re: ahhhHHH my EF driver side window broke! (pinoyboy204)
ttt
Old Jul 28, 2003 | 06:45 PM
Timmah!!'s Avatar
Is it the mechanism or the door frame itself that is bad??
Old Jul 28, 2003 | 11:07 PM
Default Re: ahhhHHH my EF driver side window broke! (azroth)
its the one holding the glass. one of the bars are bent. i can't seem to fix it...can it be replaced?
Old Jul 29, 2003 | 06:03 AM
Timmah!!'s Avatar
You can just pick up a window regulator from anyone here on HT, or you can get one from E-bay. They should not be that expensive.
Old Jul 29, 2003 | 06:26 AM
excitid's Avatar
if you go to the yard you can get the bars you need. I replaced my door after an accident and the replacement didn't have the bars so I had to take them from my original door its a bit annoying I believe you'll have to take the seat belt mechanism off but after that its pretty straight forward just remember what you removed and replace things as you remove them.
aznomb
Honda Civic (2001 - 2005)
Jul 9, 2010 03:46 AM
emwavey
10
Jul 19, 2004 07:24 AM
Chief Brody
Feb 17, 2004 09:03 PM
RATEDR
May 23, 2002 06:39 AM
