changing the rev limiter
Old Jul 28, 2003 | 12:41 AM
xxh23fuzionxx's Avatar
Default changing the rev limiter
IS there anyway you can set the rev limiter on the car. I have a OBD1 P28 ecu runnin on a B18C hatch... I wanna set my REV on a certain scale. Is it possible to do so? any ideas?
Old Jul 28, 2003 | 02:58 AM
b19coupe's Avatar
Default Re: changing the rev limiter (xxh23fuzionxx)
Chip it. The VTEC engagement point and fuel cut can be set any where you want.
Old Jul 28, 2003 | 11:04 PM
Default Re: changing the rev limiter (b19coupe)
how do i set it then?
Old Jul 29, 2003 | 07:04 AM
b19coupe's Avatar
The chip determines fuel cut and VTEC. Talk to Kenji or Katman about getting your ECU chipped.
Old Jul 29, 2003 | 03:45 PM
.xcalibur.'s Avatar
You can change redline on your ecu by getting it chipped. The only thing is that its permanent. Once the eeprom has been programmed, it cannot be changed. Im not exactly sure but i think there is an apex-i device that can change it. By the way, dont change redline unless you know your car can handle that rpm speed and you know you make power up there as well.
CheckMyFitment
Oct 14, 2013 07:17 AM
4d00rEF
11
Oct 23, 2009 01:10 AM
Tealeg88
19
Jan 20, 2006 06:00 PM
vtec69
Jul 23, 2002 07:49 AM
